Switchback Duals
Old Feb 9, 2012 | 06:35 PM
  #91
SURFOR Chop's Avatar
SURFOR Chop
Originally Posted by AFMM3
One of my father's bikes is a '98 FLSTS Heritage Springer with a spare exhaust system. He says he is putting it on his 05 FL-Dyna project bike and expects no real problems with the fit behind the rear cylinder. He is going to use an H bracket similar to your design; right side connected to tranny cover, left side to primary cover with a cross brace connected to the rear isolator.
If you've got photos of his bike, brackets and pipes he'll be mounting, I'm sure there are a lot of guys on this forum who are very interested ...
Old Feb 9, 2012 | 09:01 PM
  #92
U-234's Avatar
U-234
Great minds with great ideas. What a forum!
Old Feb 10, 2012 | 05:31 AM
  #93
blueangel73's Avatar
blueangel73
Originally Posted by SURFOR Chop
Chop- I think the issue with this setup is 1) you would have to relocate the coil 2) you would have to isolate the heat from the pipe so it would effect the stuff in the electrical box, but before you figur all that out 3) I don't think the exhaust would clear through the aread behind the rear cylinder unless you bent or modified the pipe going through this area. If you could get it to clear then I think this same area would make a good location to also installed a support braket to help keep the weight and stress off the exhaust/cylinder mount.
I have contacted V&H's in the past about going this way and they gave me a price for the crossover pipe that would run through here, i think it was only around $50-$60, a hell of a lot cheaper then the complete exhaust which makes it more fisable to toy around with without braking the budget.
Originally Posted by FBinSoCal
It is fascinating watching you guys work on this.
I have being toying with this idea for a long time, first I wanted to do this with my old sporty, then when I picked up the Bob. I just don/t have the space to start tearing apart my bike to toy around + I ride way to much to have the bike down for more then a week at a time.
[quote=SURFOR Chop;9370826Eureka ... that may be the solution right there ... just make a crossbar that would accept both right and left Softail brackets ...[/quote]
Maybe something like this (slightly modified to account for the belt/guard). Might even be able to use it with the cross under exhaust provided it can support the weight of the exhaust pipes!
Old Feb 10, 2012 | 10:47 AM
  #94
SURFOR Chop
I tend to disagree with your objections ... although I haven't gotten out the measuring stick and caliper to check the specifics down to the last detail ...
I don't think the heat factor by the fuse / electrical box will be that much greater ... maybe a little, but not enough to screw anything up in there ... the whole assembly is only inches behind one of the hottest parts of the bike as it is--the rear cylinder head ...
... maybe add a half inch of fiberglass insulation to the fuse box cover and call it good if it is that great of a concern ... also, aren't the fuse panel and the ECM in the Softail surrounded by boiling oil ...?
The coil is just about the same place on the Dyna and the Softail ... unless I am mistaken ... it could be mounted slightly more inboard on the Softail ...
... but, even if the Dyna coil is an obstruction, one could move it to the position where the stock horn is ... I suppose it depends on how motivated one is to do this ...
... see, for example forum member nkauf21's thread here ... https://www.hdforums.com/forum/dyna-...elocation.html
I really like your concept for the dual bracket ... very nice ... just need to make sure it doesn't weigh you down too much ... maybe bore some holes in the crossmember ....
I don't know what is keeping you from pulling the trigger on this and proving to the world (or hdforums at least) that it is do-able ... go ahead on wit' yo' bad self ....
R/
'Chop
... just think how great those 'cholos' would look on your sled ...
Old Feb 10, 2012 | 11:54 AM
  #95
bikerlaw's Avatar
bikerlaw
Originally Posted by blueangel73
WOW! That is one sharp motorcycle.
Old Feb 10, 2012 | 12:35 PM
  #96
blueangel73
I wasn’t trying to say that the idea of using the cross-over pipe is a bad idea; in fact I totally agree that it would be an awesome way to install the Softail true-duals on a Dyna.
What you stated about the heat issue make since, I didn’t take into consideration the electrical components being surrounded by all the oil heat on a Softail, mainly because I have never owned one and thought that the battery was the only thing in there.
I guess the coil just looks to be a little closer to the primary cover to me, I’ don’t know if it is or not. Guess I figure that one out when I fit a pipe or see that someone else has.
As far as the bracket idea, I took your idea and just modified it a little. I think some ź” thick aluminum welded together to achieve that dimensions needed while using as little material needed could be light enough and strong enough to achieve the required bracket.
I have also looked at the Bassani Hutch system because it is routed a different way. After a few calls with Bassani about fitment, they told me that with a little modification to the head pipe coming off the front cylinder (it would have to be tightened up some, closer to the cylinder because the pipe would vibrate against the down tube of the frame), there was no reason that they could see as to why this system wouldn’t work on a Dyna outside of the hanger we have been disusing. And with the pipes all blacked out (contrast wise) these could look really good.
And yes those ‘Cholos’ would be awesome.
When I have the time and money, hope fully sometime soon I will be pursuing it!!
Attached Thumbnails Switchback Duals-18001201a.jpg   Switchback Duals-18001201.jpg
Old Feb 10, 2012 | 10:12 PM
  #97
ackman1968's Avatar
ackman1968
Only issues I came up with while drooling over a heritage with true duals is the transmission cover and the shift lever location. I think the Dyna trans will make it necessary to mod the rear pipe to clear these items.
Old Feb 10, 2012 | 11:32 PM
  #98
SURFOR Chop
Rick
You're saying you don't think the clearance in the area I circled in red has as much space for the pipe to transit through as the Softails ...? I'd think it would be easy enough to determine ... the pipe is 1-3/4" diameter and there is practically NO space on either side of the Softail pipe as far as I can see from the photo ...
(Even assuming you put the bent shifter rod in lieu of the straight one to remove that obstacle ....)
Too bad we couldn't get one of the pipe makers to find a willing test subject to put the question to a test and prove conclusively once and for all ... seems like from the interest it is generating here, it might expand the market for pipes they're already making for Softails by simply adding a bracket adapter for Dynas ... it could possibly expand their market quite significantly for not a lot of additional costs ....
R/
'Chop
Just went out to the garage and snapped a few photos ...
... what I said above might apply to the '06 and later Street Bobs, but I don't think I'll be able to do this conversion ... maybe if I was able to replace the transmission top cover with a different style and replace that oil hose with a hard brass line that is routed a little tighter against the surface of the transmission ....
... don't think it would work with my oil filler cap where it is currently located ... would have to investigate the options for the transmission top or look at the other type of dual where the front pipe goes to the left side ....
Attached Thumbnails Switchback Duals-dsc00374-v-2_0.jpg   Switchback Duals-img_0089.jpg   Switchback Duals-img_0091.jpg
Old Feb 11, 2012 | 12:00 PM
  #99
LDB187's Avatar
LDB187
Nice but I'll just hold off until they can come up w/some straight shots
Old Feb 11, 2012 | 02:58 PM
  #100
SURFOR Chop
Okay ... stopped by the dealership at lunchtime ... (even snapped a few pics ... will post later as I cannot post from this computer) ... I am almost dead certain that the rear headpipe will fit an '06-later Dyna ... I compared the space behind the cylinder of the Heritage Softail Classic to Street Bob and Super Glide Custom ... there is NO reason the pipe should not fit ...
Now ... the '05-earlier Dynas would most likely not be able to fit the pipes due to the shape of the Transmission cover, the oil return hose and the oil filler obstructing the space ... I am kind of thinking that one could get the exhaust kits and piece together a rear exhaust head pipe for the '05 and earlier that would fit through that space ... but, based on the photos I posted earlier ... I believe that particular pipe would not fit the '05-earlier Dynas ....
R/
'Chop
