Question on Turn Signal Relocation Kit
Old Mar 4, 2012 | 04:15 PM
Flinter's Avatar
Flinter
Default Question on Turn Signal Relocation Kit
I bought the Harley relocation kit for my Street Bob awhile back. Finally got the money to order saddlebags so I started installing it today.
First thing I had to do was go buy a motorcycle jack. No problem.
Then I came home and lifted it enough to get the rear tire off of the ground. I figured that would drop the tire out of the way of the bolt that runs through the fender.
Nope. Still won't clear it.
Do I have to disconnect the shock or am I missing something? I assume that taking out the bottom bolt is the easiest way to go?
Old Mar 4, 2012 | 04:17 PM
djack's Avatar
djack
yea just take bottom bolts out, drop the wheel down,all kinds of room
Old Mar 4, 2012 | 04:21 PM
Flinter's Avatar
Flinter
Thanks man.
Old Mar 4, 2012 | 05:03 PM
RebelGlide's Avatar
RebelGlide
strange I just put the relocation on my bob never needed a jack or anything and bolts came right out.
Old Mar 4, 2012 | 05:54 PM
Flinter's Avatar
Flinter
Strange. Mine won't clear the tire. I even tried deflating it a bit.
Old Mar 20, 2012 | 08:29 PM
twister2gt's Avatar
twister2gt
not trying to thread highjack but i just got the kit and I'm really don't understand what you are doing when i comes to the wiring and pulling the wires out of the connector part of the instructions, Do i need to add more wire to them because my kit didn't come with wire.
Old Mar 21, 2012 | 09:51 AM
Flinter's Avatar
Flinter
You don't have to add wires. What you have to do is remove the wires from the plug so that you can get the signal wires through the hole in the fender. Then you reroute the wires underneath the fender instead of through the hole.
It really is a horrible set up. Unfortunately, it's the only one I know of.
Old Mar 21, 2012 | 10:38 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Check out this post on how to open & disconnect wiring from AMP connector....
https://www.hdforums.com/forum/8040670-post34.html
Old Mar 21, 2012 | 07:20 PM
atretes1's Avatar
atretes1
I didn't like the Harley set up so I went this route. It works good.
http://www.amazon.com/dp/B00311VJF0/...SIN=B00311VJF0
Old Mar 21, 2012 | 07:53 PM
2011FXDC's Avatar
2011FXDC
When I did my wife's Sportster I actually cut the wire and soldered them back together after pulling them through. They provided some crimp connectors in the kit but solder and heat shrink are my preference.
AlCherry
Jul 19, 2010 01:20 AM
j.m.s.
Feb 2, 2010 11:28 AM
biskit
Jul 19, 2007 04:07 PM
geoprofjon
May 30, 2007 02:49 PM
millermeteor
Apr 5, 2007 05:22 PM
