Primary Cover Gasket Replacement?
Old Jul 14, 2017 | 12:12 PM
jbikerj's Avatar
jbikerj
4th Gear
Default Primary cover gasket should be replaced when you disturb the joint. Also ensure both inner primary and primary case gasket sealing areas are cleaned and free of any nicks or burrs. If you see a nick on the gasket sealing area, hit it with a sharpenin
[QUOTE=kennyking0810;9478530]I am about to install a new diaphragm spring that came with my reduced effort clutch kit. Unfortunately it will not fit through the derby cover and need to remove the entire primary cover to replace it. If removing the primary cover, is it a necessity to replace the gasket as well or can I reuse it? I've read that I can reuse the derby cover gasket but can't find a sure answer on the actual primary gasket. Thanks[/QUOTE
Change the gasket is the best bet. Make sure the gasket sealing areas are clean.
Old Jul 14, 2017 | 07:18 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I've re-used my primary on the '13 at least three times. I have a spare gasket hanging in the garage. I clean the surfaces on the primary case and pri. cover and dry/inspect the metal gasket for tears or deformaties prior to installation. Torque the screws as required in the service manual. I do not have leaks. The primary is not pressurized, it's a splash pan for the chain and clutch and what ever hits the stator/compensator. Do you feel lucky. Do you?
baka1969
Oct 5, 2023 05:31 AM
magazine
EVO
Aug 16, 2012 10:54 PM
beasleyiv
Mar 1, 2011 01:08 PM
trip20
Aug 6, 2010 03:14 PM
matschang
Jul 29, 2006 01:13 AM
