Proof you don't need a tuner
For those of you who claim that your engine life will be shortened, or damage done, where are your stats for that? I've seen none, just the opposite in fact.
As for my bike.............2011 FXDC.......Vance and Hines slipons (cats were in the mufflers, so they're gone)........SE airbox..........download..............my bike runs great.............cooler..........no pops, backfires, etc. .............crisp and clean. So, am I hurting my engine?????
So his actual question is: "Yeah, so everybody says you don't need to do a tune, but I did a tune and my bike isn't damaged! So what's up with that?!?!"
Good grief.
I posted before that I know of two bikes with lots of miles, and no problems. Some of you say the download does nothing, some of you are saying it IS a tune. So which is it?
So, I assume they don't realize that they spent half the cost of a tuner to buy a single tune.
Even then, the downloaded tune is a general version for one's general setup, not a specific tune for a specific bike.
I posted before that I know of two bikes with lots of miles, and no problems...
That's why most of us here have been saying that you CANNOT make blanket statements like "never" or "always", because everybody's situation is different.
The ECM (Engine Control Module) in your bike came from the factory with specific settings. Downloading different ECM settings retunes the engine. Period. Just because the changes weren't determined using a Dyno doesn't mean changes weren't made.
Lots of people say lots of things on the internet.
14.7 is fine for idle or super-easy puttin', which is about the only time the engine runs at that mixture. Once the throttle opening and rpms increase, the bias table values cause the mixture to richen (while still in closed loop), and it's no longer at 14.7.
As throttle opening and rpms increase further, the system goes into open loop, and the mixture gets richer yet. So 14.7 doesn't have much to do with the actual fuel/air mixture used during most riding.
Sure, richening beyond factory-ish values will cool the engine a bit, but I don't ever ride in "Daisy Dukes"
I haven't decided how much money I want to put into mine, because I still have this Road King fantasy spinning around in my head.
But, in the meantime I wanted my bike to run as well as it could, particularly given the fact that it gets pretty hot here in the summer. And, if I do decide to start doing things, I'll need the tuner module anyway. So, I bought a SEPST and had a tech who knows what he's doing do a smart tune for me. Two hours labor. Can't beat that.
Keep in mind, the bike is bone stock. I had a before and after dyno run done, just to see what happened. AFR dropped to the mid-13's, and from about 1,500-3,500 rpm I picked up between 4-5 ft-lbs of torque and 2 hp. Decel popping is gone. Throttle response is enormously better!
Bone stock, just a quick tune. I'm a happy camper.
A "dealer download", particularly in California, will make sure your bike stays in stock tune if you make some mods. It probably won't make your bike non-EPA compliant.
I used the SEPST and had the bike's tune changed to make it run as well as the engineering team knows it can, and it is absolutely no longer EPA compliant.
