V&H baffle change made easier
Old Mar 9, 2012 | 08:31 AM
Bagger Jim's Avatar
Bagger Jim
Default V&H baffle change made easier
After changing out the baffles in my big shots, I started to think, "why in the hell do they make you take off the heat shields to change the baffles out. So,... I removed the shields again, measured the distance to the retaining bolt, and drilled the shields so next time, I won't have to remove them to pull or change the baffles out.
First, I measured and marked the location on the heat shield.
used a center punch to start the drill and drilled a 3/16 pilot hole. Then used a unibit (step drill) to make a 5/8 hole so the bolt would be easy to get out.
Pardon the crappy pic, it's hard to get into a position to take a picture of the inside of the pipe, but you get the idea.
Worked out great. Now if I just want to run without the baffles, they're easy to remove and reinstall.
Old Mar 9, 2012 | 09:16 AM
bsljacques's Avatar
bsljacques
That's a great Idea!!!! I think I may have to do this also!
Old Mar 9, 2012 | 09:24 AM
Kevin1169's Avatar
Kevin1169
Do you think it was put under the shields like that so if it vibrated loose you wouldn't lose the baffle? I was thinking of doing the same thing.
Old Mar 9, 2012 | 10:27 AM
Bagger Jim's Avatar
Bagger Jim
Don't know, but every time I've changed/removed the baffles, that screw was as tight (or tighter) than when I installed it.
Old Mar 9, 2012 | 01:03 PM
pontiac69's Avatar
pontiac69
i have changed my baffles about 5 times now and everytime i do i think about doing this mod. it would make it so much easier, but my dumbass never does it. i was thinking of throwing the qq baffles back in. and now i have to pull the heat shields off again. great mod to do on these pipes. i also thought about the screw backing out, but everytime i took my baffles out the screw was tight.
Old Mar 9, 2012 | 03:16 PM
onemyndseye's Avatar
onemyndseye
excellent idea!
Drilling ok for the ceramic coated sort?
Old Mar 9, 2012 | 03:42 PM
Robbie13's Avatar
Robbie13
LOSER
Excellent idea! And so simple.
Old Mar 13, 2012 | 08:41 PM
VNV BONES's Avatar
VNV BONES
Stage I
Default Baffles
I tried for an hour today to remove baffle from my Big Radius V.H. , no luck, I only tried one of them , when it didn't work I figured I better try here . Oh yeah I'm new here so Hello to all .
Old Mar 13, 2012 | 11:47 PM
roneil's Avatar
roneil
Welcome to the Forums from St Charles MO.
Old Mar 14, 2012 | 12:47 AM
Tat2u's Avatar
Tat2u
yeah i did this when i fitted my quiet baffles, also changed the dome head to a regular cap head, the allen keys fit in the regular cap heads better and are also one size up
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
