Tachometer 03 lowrider
Old Mar 16, 2012 | 08:03 PM
kennyking0810's Avatar
kennyking0810
Default Tachometer 03 lowrider
Does anyone know if the tachometer is suppose to be illuminated on a 2003 dyna lowrider? I know that the speedometer is obviously suppose to be illuminated but can't remember if the tach is. Thanks
Old Mar 16, 2012 | 09:25 PM
Austin Dave's Avatar
Austin Dave
Yes, both are illuminated on mine.
Old Mar 16, 2012 | 11:38 PM
kennyking0810
Austin dave, does ur tac light up when the key is turned on or only when the bike is started?
Old Mar 16, 2012 | 11:40 PM
Austin Dave
Key On
Old Mar 16, 2012 | 11:45 PM
kennyking0810
Ok. I changed out bars and took the tank off in the process. Tac, fuel gauge, and neutral light no longer illuminate. Always something.
Old Mar 17, 2012 | 07:45 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Ref these wiring diagrams from my database...
full color 2003 Dyna Glide Wiring Diagram (Dom. & Int. Models), Horn and Instruments (page 1 of 2)
added 11-09-2011
full color 2003 Dyna Glide Wiring Diagram (Dom. & Int. Models), Horn and Instruments (page 2 of 2)
added 11-09-2011
...it sounds like the orange wire (instrument 12 v power feed) doesn't have 12V power.
I'd start checking the 15amp instrument fuse first.
If the fuse is OK, then check if the orange wire that comes from your electrical panel has 12 V power.
Then check the orange wire in the connector at at the end of the main harness where it is connected to the speedo connector.
Work your way up towards to where the instruments connect to the orange wire.
Old Mar 19, 2012 | 07:37 PM
kennyking0810
Checked the fuse and sure enough, it was bad. FXD2003Rider, thanks for the good info. So thankful it was something so simple.
Old Mar 20, 2012 | 03:17 AM
FXD2003Rider
Glad you found the "troublemaker".
Your feed-back is much appreciated
AJ88V
Dec 13, 2018 07:46 PM
AJ88V
Electrical/Lighting/Alarm
Dec 3, 2018 11:14 AM
del50man
Mar 16, 2016 10:18 PM
HDF Tech
Jun 14, 2009 08:30 AM
fiftyonefive
Jun 2, 2007 01:17 AM
