Help!!
Old Mar 18, 2012 | 06:29 AM
8541hog's Avatar
8541hog
Is it cranking normally or slow? Have you checked the voltage on the battery? The ECM shuts down the ignition if the battery falls below 12v so it will not start. If your battery is low you may not be charging when running, this explains why it started a couple times then will not start any more. Initial problem may have been the sensor, but you may also have a charging or voltage Reg issue.
Old Mar 19, 2012 | 10:35 AM
Jperk1966's Avatar
Jperk1966
6th Gear
The Battery is brand new and the voltage is good. At this point I believe it is the ECM. I will know for sure tomorrow when I take it in for diagnostics.
Old Mar 21, 2012 | 06:02 PM
Jperk1966's Avatar
Jperk1966
6th Gear
It is starting now but it is only firing on one cylinder. The Jackass that repainted my tank didn't clean out the tank and the fuel filter was completely clogged and the fuel pressure regulator was messed up. Now I am thinking I have a clogged fuel injector.
skipperhd1
Jul 17, 2020 07:55 PM
Master Dee
Feb 20, 2019 01:11 PM
rocknride71
2014-2024 Touring Models
35
Apr 23, 2017 02:46 PM
jmb79
Sep 20, 2016 09:23 AM
C-harmer
Sep 6, 2011 03:23 PM
