help! engine turns over but won't start
Old Jul 30, 2014 | 05:58 AM
skipperhd1's Avatar
skipperhd1
Cool help! engine turns over but won't start
hi guys! i've got a 2006 road king efi. riding home from the bar last night. the engine just shut down like it is out of gas! a biker in a pickup truck stopped and drove me to the gas station. after adding a gallon of gas the engine will turn over but won't start , the bike was not out of gas! anybody got any quick ideas i don't want to call the dealer to come pick it up! cheers from montana
Old Jul 30, 2014 | 06:41 AM
NELS's Avatar
NELS
First thing is to check for codes to find right direction to go in. Good Luck.
Old Jul 30, 2014 | 09:07 AM
Boomer1143's Avatar
Boomer1143
Can you hear the fuel pump running when you turn the ignition on?
Old Jul 30, 2014 | 09:50 AM
mkguitar's Avatar
mkguitar
or do you smell raw fuel at the exhaust pipe? ( which says whether fuel system is working- or not)
check fuses
"just shut down" says electrical problem
"like it is out of gas" would suggest it stumbled before dying- which would be a fuel delivery problem
mike
Old Jul 30, 2014 | 10:07 AM
Blueflame1's Avatar
Blueflame1
Check the Fuel Filter, or, perhaps you need to replace the In-Tank Fuel Lines.
__________________
Old Jul 30, 2014 | 10:53 AM
jrdfatboy's Avatar
jrdfatboy
That happened to my 07 street glide. Turned out to be the valve on the bottom of the fuel tank, it has a check valve. Mine kept closing shutting off fuel flow, push it up toward the tank and you will feel it detent. If that works change it out, it will keep closing on you.
Old Jul 30, 2014 | 11:57 AM
Clubber's Avatar
Clubber
Check your spark plugs and wires too.
Old Jul 30, 2014 | 01:17 PM
indyfjr's Avatar
indyfjr
6th Gear
Check the fuel pump relay under the seat, if you don't hear the fuel pump energize when turning on...
Old Jul 30, 2014 | 02:27 PM
journeyman's Avatar
journeyman
Are you sure it was not out of gas? If it was, you could have a frozen injector.
A good place to start would be to see if you are getting fuel, and spark, then take it from there.
Old Jul 30, 2014 | 04:21 PM
just plain john's Avatar
just plain john
Spray some starting fluid (ether) in the throttle body while you're trying to start it. If it does, it's a fuel problem. If not, it's no spark. As mentioned, check your codes.
