Dynojet PC V problem
Old Mar 18, 2012 | 07:37 AM
jake40ma's Avatar
jake40ma
Default Dynojet PC V problem
All,
I've got a 2009 Fatbob with a stage one and PC V installed from Fuel moto
Been having a weird problem.Bike starts fine then after riding for awhile and shutting off, I go to restart it and it won't start unless I give it throttle. At this point it will not idle. It will run alright but with huge backfires. What cures this is I shut bike off and restart and problem is gone. I've found that if I try to start it and it won't start, I shut the ignition off then turn it back on and everything is fine and will not screw up at all during this run cycle. So it basically seems to me if I recycle the ignition when it won't start the problem diaapears. Any clues on what I should do or what I should look for? It's driving me crazy Thanks
Old Mar 18, 2012 | 07:39 AM
luc.who's Avatar
luc.who
A couple of things I would do is to check for a good connection or bent pins at the connection. I would call FM Monday morning, they can help you out pretty quick.
Old Mar 18, 2012 | 08:07 AM
nathanw's Avatar
nathanw
You might have to re-load the map.
Old Mar 18, 2012 | 09:47 AM
Skid Lid's Avatar
Skid Lid
Call fuel moto, my guess is they send you the map to reflash it with, thats where I would start, simple free and most likely the problem.
cbi1000
May 18, 2013 09:47 AM
18BKLR
Jul 2, 2010 10:09 PM
Rex_Vaginas
Jun 16, 2010 01:26 PM
AdrianVall
Sep 11, 2008 01:45 PM
ktoolelv
Jul 7, 2006 12:25 AM
