Replacing pulley bolts
Old Mar 22, 2012 | 01:49 PM
paulies 07's Avatar
paulies 07
Thanks for the info everybody, will put that project on hold
Old Mar 22, 2012 | 02:04 PM
WS6 Formula's Avatar
WS6 Formula
Originally Posted by WS6 Formula
I used new chromed grade eight bolts, re-tapped the hub threads, cleaned all of the threads with electrical contact cleaner, applied red loc-tite , torqued to 60 ft lbs, and no problems since.
Some info from other threads below, click on the blue arrow to see the whole thread.
Are you sure the threads are missing, or is the first half inch a counter bored hole?
I've heard of this happening before and it is usually after someone puts a new pulley or pulley cover on, as well as ones that have it all original.
I wonder if you have an original untouched bike and verify the pulley bolts torque with a torque wrench that you inadvertently move the bolt which would break that Loc-Tite and cause the bolt to eventually back out.
Which ever way you go (new wheel or not), get new grade eight bolts and clean all your threads with electrical contact or brake cleaner, or any other solvent that doesn't leave a residue, use red Loc-Tite and torque the bolts once.
weezl
Jun 24, 2019 11:51 AM
Jlopez44
Wheels/Tires
20
Apr 15, 2019 08:11 AM
HarDlife
EVO
15
Mar 26, 2014 07:22 AM
anubisss
Jul 19, 2011 04:28 PM
919streetbob
Sep 28, 2009 06:37 PM
