power commsnder
Old Apr 1, 2012 | 04:12 PM
edjack's Avatar
edjack
Default power commsnder
i have an 08 streetbob with a 96 ci . i want to install a power commander III on it. i am having a problem taking off the o2 sensor wires to put on sensor elimitaters. i would be graetful for any info thanks
Old Apr 1, 2012 | 04:16 PM
mibeaulieu's Avatar
mibeaulieu
Try heating them with a torch - that should loosen them up.
Old Apr 1, 2012 | 04:19 PM
mibeaulieu's Avatar
mibeaulieu
Oops - thought you were talking about the sensors themselves.
Old Apr 1, 2012 | 04:31 PM
Rainmakr's Avatar
Rainmakr
Take a look at the attached photos from Fuel Motos instruction sheet. There is an O2 sensor under the seat and one up by the front head pipe. If you are having trouble locating the plugs follow the line back from where the O2 sensor is plugged into the pipes. Once found disconnect and put eliminator on the connector. Good luck!
Attached Thumbnails power commsnder-fuel-moto-o2.jpg   power commsnder-fuel-moto-02.jpg   power commsnder-fuel-moto-o.2.jpg
Old Apr 1, 2012 | 04:32 PM
maddghost's Avatar
maddghost
should be a little tab between the male and female counterparts either pull up gently with a screwgie or push down and pop them apart.
bald1der
Feb 17, 2012 04:18 PM
braves
Jul 18, 2011 07:21 PM
FX4
May 2, 2008 09:59 AM
Z6969
Jun 23, 2006 11:45 PM
Z6969
Jun 23, 2006 04:35 PM
