Broken stud in trans from muffler bracket! Known Harley problem?!?
Old Apr 4, 2012 | 08:52 AM
HDexplorer's Avatar
HDexplorer
Angry Broken stud in trans from muffler bracket! Known Harley problem?!?
What the hell?? I was taking my rather tame SE slip-on system off my 09' Fat Bob to install my Crossbacks and there was a bolt on the bottom left corner of tranny that holds the factory muffler bracket in place. It was sheared off but held in place through the double nut. Crap!
The worst part is I searched this forum for tips on extracting this little begger from my transmision case and there is an old thread on this problem:
https://www.hdforums.com/forum/dyna-...cket-stud.html
I'm calling Harley to see if they can help me out on this "known", issue. MY warrenty is gone but we'll see!?!?
Anyone else out there have had this problem?
Old Apr 4, 2012 | 11:04 AM
MayDay607's Avatar
MayDay607
6th Gear
I sheared that bolt off on my Wide Glide from dragging the stock pipes in corners. Mine was under warranty though, so the dealer took care of it. Good luck.
Old Apr 4, 2012 | 11:28 AM
07bobber's Avatar
07bobber
Get yourself a set of easy outs and go to town....
Old Apr 4, 2012 | 11:34 AM
Robotech's Avatar
Robotech
Same here on my Wide Glide. I had two broken off. They told me it was a common problem and fixed it under warranty. I discovered it when I took off my stock pipes to put on my new V&H Bigshots so I just had the bike towed to the dealer with the stock pipes still off and just had them install the new pipes once they got the bolt issue fixed.
Old Apr 4, 2012 | 06:38 PM
HDexplorer's Avatar
HDexplorer
Well, warrenty is over and since I'm the second owner I'm not getting anything from the Harley dealer, only an offer to book it in a month from now and at least a $100 to fix it if all goes well.
So I'm cheap and I don't want to wait so after a couple calls to some buddies I got some free advice.
Picked up a set of good quality square end easy-outs, a HSS drill bit, and a metal punch. I was told that the best penatrant for steel in aluminum is diesel fuel. So I soaked a small rag and stuffed it in the hole. I'll keep doing that for the next day or so and pray that it will lossen off. Then pray that the drilling and easy-out will work.
Wish me luck!
Old Apr 4, 2012 | 07:40 PM
ghostrider69's Avatar
ghostrider69
A set of carbide left handed drill bits and a set of ez-outs will get that sucker right out of there.
Old Apr 4, 2012 | 08:04 PM
paul s's Avatar
paul s
I've cut grooves in broken studs then just used a screwdriver, It depends on how much you have to work with, I drill them then use an easy out if that doesn't get it..
Old Apr 5, 2012 | 02:19 AM
Tat2u's Avatar
Tat2u
Left hand drill bits are the go. Hopefully they will grab and screw the ****er out without even needing the ezy-out. Break one of those off in there and your in for a whole new world of pain
Old Apr 5, 2012 | 08:16 AM
128auto's Avatar
128auto
This is what happen when steel meets aluminum, sorry to hear that.
buick_81
Jul 17, 2014 02:31 PM
Twrguy
Jul 7, 2011 06:46 AM
KaponeWKYA
Jul 17, 2009 07:41 PM
Ultrasweet
Oct 28, 2008 07:11 PM
uemjg
Jul 16, 2007 09:53 PM
