Flare Windshield for Switchback, how much taller
accurate messurement of the height so I could Campare the 2. Klock Werks, gives
many deminsions, but the over all height is not given from a comparable spot on both
windshield. Seeing all the other measurements are not the same on both windshield,
but the mounting holes are, it's the best way to get an accurate measuement, using
them as a starting point. Using that Center mounting hole and measure from the center
hole to the top, should give the correct height and now all I have to do is measure on my
stock windeild and I can actually tell how much taller the Flare windshield is going to be.
Thanks, this messurment should do the trick.
Hope you enjoy the new Windshield
