Rear Turn Sig mods. ??
Old Apr 25, 2012 | 08:02 PM
Kaycee's Avatar
Kaycee
Default Rear Turn Sig mods. ??
Need to put my turn sig. back to the back strut hole (05 WG),don't like the looks of them on the tail light.I like the stock arm, nacelle,wing or what ever it called but it needs 2 hole's 1 for the bolt and 1 for the wire.I don't want to drill another hole either,has any one replaced the bolt for the hollow 1 to run wire through ?and has anyone cut down the wing so it sits alittle closer to the strut .I was thinking of cutting about an 1 1/2" off which I feel would look alot better.Can any one shed some light on this
Old Apr 25, 2012 | 08:24 PM
LoBoT's Avatar
LoBoT
Yep, use a hollow to run the wire through. Any dealer's parts guy can fix ya up. The turn signal connecter won't fit so you'll have to cut and splice the wire.
I don't have a clue on cutting down the mount. Seems like it might cause the chrome to peel. there are a gazillion after market mounts and sigs to choose from though. Maybe one of them will suit. At any rate, have fun and good luck tinkerin'
Old Apr 25, 2012 | 08:34 PM
schwangster's Avatar
schwangster
Debrix used to have short signal mounts. Probably others too.
I know what you mean about the way the mount looks.
Old Apr 26, 2012 | 02:25 PM
Kaycee's Avatar
Kaycee
Can't seem to find them but I'll keep looking,I thought I had read some time ago that a guy had cut them down .
Old Apr 26, 2012 | 04:20 PM
schwangster
http://www.debrix.com/Short-Turn-Sig...31-0554-vt.htm
Old Apr 26, 2012 | 09:07 PM
Kaycee's Avatar
Kaycee
Thanks man have you tried these ,I think this would work and then drill a bolt for the wires
Old Apr 27, 2012 | 03:40 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Here are some images (posted by mud) showing different types of stand-offs:
A far as I know the p/n's are:
68480-02 stock Dyna (long) version
69820-06 HD short version
68821-00 FXSTD style (= shortest);
No need to cut the wires: check out this how to open the connector info:
https://www.hdforums.com/forum/8040670-post34.html
maddghost
May 31, 2013 07:00 AM
rlbailey
Dec 28, 2011 09:26 PM
Marky the Sparky
Electrical/Lighting/Alarm
Nov 15, 2010 02:52 PM
SniperCJ
Dec 16, 2009 01:05 AM
clear33765
Jun 2, 2007 11:34 PM
