WOW I'm just learning now that GPR is making this units for Harleys now! how different are they from the ones for dirt of sport bikes? is it just the mount that changes?
How much sag did you get with your added weight vs. the bike standing by itself on the ground?
Brians (from Ricor) recomendation was 1 1/4"-1 3/4" of sag with riders weight. Mine came out at 2 1/4 so it looks like I didn't cut quite enough
Either I have way too much preload, or I'm measuring wrong...I'm only seeing 1/2" difference in sag between bike on the jiffy stand, and bike upright with me on it. Maybe my feet being on the ground affects it?
I'm so pleased with the road feel and handling that I'm wary of making changes, but if I'm not getting enough sag, perhaps it could be even better.
Originally Posted by 619bob
Thanks Squid, you beat me to it!
Yep, Bob...I have it bookmarked on all my devices!
It's freakin' awesome. Looks just like powder coat up close, but peels off if you want to change it or gets torn. I have it all over the bike. I did the bottom half of my chrome dust covers to match the black lowers. The upper half is hidden under the jammers. I used it to cover the factory VIN stickers on the frame. It's really hard to spot where it ends and the power coat begins. It's not super-sturdy, but holds up to light rubbing/abrasion. It will tear if you hit it with something hard, like a wrench. I also use it to protect power coat where cables rub, like my trees and risers.
The section between my trees gets marred by my fairing clamps, but I use the marks to line it up when I take it on and off.
Either I have way too much preload, or I'm measuring wrong...I'm only seeing 1/2" difference in sag between bike off the jiffy stand, and bike upright with me on it. Maybe my feet being on the ground affects it?
Quote:
peel back your covers and put a zip tie on the bottom of the exposed fork tube and then get on the bike and balance it without your feet on the ground. Then you can measure how much the zip ties moved. I had a feeling you had too much preload with your weight and the 1.0 springs. I kinda think the .96 would have been better for you but the 1's will work but you may have to cut at least another inch off. (after you check the sag with the zip ties)
Now that you have spent the money, you want to go the extra mile to dial it in. If it feels this good now...just think about what it could be. Keep us all updated.
Ah ha...got it. I'll try it that way and see.
Traxxion's choices were either .90kg or 1.0kg...nothing in between for single rate.
I'll post an update soon. Home sick today, so I won't be riding anywhere, but I might be able to convince my wife to let me sit on the bike long enough to get a measurement.
