Front suspension upgrade
Understand feet OFF the ground, thanks.
So, I put some shoes on and went out to the garage. Measuring your way with the zip tie on the fork, I'm only getting 3/8" of sag. Of course I proceeded with pulling out the jack, putting the bike in the air and taking everything apart. I cut a whole inch off the spacers, which obviously put them an inch below the top of the tube. When I put the adjusters on, they screwed right down with no resistance, so I put 8 full turns on each (8 turns = 1 inch).
I buttoned everything up, torqued the pinch bolts, cleaned up the spacer shavings and oil, stowed the jack and put all my tools away just in case my wife busted me out of bed. I took another couple measurements. Both were 3/4", so I backed the adjusters all the way off and got 1 1/8". I'm not comfortable having them that soft, so I put 4 turns on and remeasured...1". I got it all done in less than an hour, whew.
That's where I'm going to leave it for now (I know...said that before). I'm going to bring a hex with me to add more resistance to the adjusters if the ride is too soft tomorrow.
I'll post an update after my morning commute...assuming I don't still have a fever when I get up.
Crap I couldn't do that in an hour on a good day. Glad the wife didn't catch you playing.
It wouldn't hurt to call traxion...maybe you needed a slightly longer spring? Those caps should be a real bitch to get on with those springs...
He recommends calculating total travel of the forks first, with the springs and spacer removed, fully compressed to wheel fully off the ground. Then get sag by measuring the travel with springs and spacers installed with rider weight on the bike. That sag should be 1/3 of the total travel for the Intiminators and single rate springs to do their thing.
I owe SC-Longhair a shot of the Traxxions compared to the stock springs anyway, so I'm going to take it all apart again this weekend and measure everything. I've gotten pretty good at taking it all apart and putting it together now. In the meantime, I'll keep stress testing it on the freeway and take notes.
The second measurement is the sag but you need to know what what % that is when compared to the first measurement - most people recommend it should be anywhere from 25% to 33 %. If you like it a little stiffer shoot for 25%, plusher 33%.
For my Fat Bob the total travel was 4 5/8" and the sag was 1 5/16" for a % of 28.4%.
The second measurement is the sag but you need to know what what % that is when compared to the first measurement - most people recommend it should be anywhere from 25% to 33 %. if you like it a little stiffer then 25%, plusher 33%.
I'm heading out shortly to road test the feel of the shorter spacer. Like Rooti, fabrik8r things that 1.0 spring is too stiff for my body weight. We'll see.
I suppose it would always be better to do your own math on your actual bike but Alans measurement shows that Brians math worked out pretty much the same in the end.
The ride in wasn't as good as my previous ride with the longer spacer. It felt kinda mushy in places. It wasn't bouncy or anything, just not as smooth and tight as before. Rain grooves and seams were more noticeable, and the 3 big "jumps" on the 5/805 split weren't as dampened as before. Still better than before the mod, but not as nice as it was with the longer spacer. I put 2 full turns (1/4" more preload) on the adjusters for the ride home, and that tightened things up.
That's 60 miles of road test for today. I'm taking the train tomorrow, so I'll post another road test update on Friday before I take it all apart again this weekend. I'm gonna add 2 more turns (1/4") of preload and see how that 5/805 split feels.
