t-bars tall risers gauge mount question
Old May 16, 2012 | 11:50 AM
jslum's Avatar
jslum
Default t-bars tall risers gauge mount question
anybody ever use frame clamps like for clutch cables instead of the accutronics gauge mount to relocate gauges? there a lot cheaper just wondering if it will work
Old May 16, 2012 | 12:07 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I just did that on mine. Clamps are $12.95 each, the Accutronix mount is ab out $100 or so. Here are a few pics.
Old May 16, 2012 | 12:11 PM
Patman 13's Avatar
Patman 13
Yep. I did it too. Has worked well for me.
Old May 16, 2012 | 12:43 PM
lk3k9's Avatar
lk3k9
I did it as well, works great.
Old May 16, 2012 | 12:52 PM
gartec81's Avatar
gartec81
how hard is it to hook up a tach. my street bob didnt come with one. what do I do then?
Old May 16, 2012 | 01:12 PM
Hogpro's Avatar
Hogpro
Former Sponsor
You need the tach and the bracket for the speedo and tach. I am not sure where it plugs in but it can't be that difficult to do.
Here is a thread ab out doing it.
https://www.hdforums.com/forum/dyna-...er-needed.html
and here is a list of part numbers.
67121-95 gauge gasket
48073-04 dual gauge clamp
2361 screw (2 each, to hold tach into above clamp)
72131-04 socket housing, 12-way(gray)
72189-04 seal pin (10)
74196-04 terminal, socket (14)
74197-04 socket lock, secondary, 12-way
seal pin (10) & terminal, socket (14)....quantity is listed for both gauges, count the pins on the gauge to see how many you will need for the tach.
__________________
Old May 16, 2012 | 02:23 PM
sonnydaze's Avatar
sonnydaze
do they come in 1 1/4 for big bars
Old May 16, 2012 | 02:33 PM
Patman 13's Avatar
Patman 13
Yes. I got 1 1/4" clamps for mine from J&P.
Old May 16, 2012 | 02:59 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Yup. Those are the 1.25" ones. They alos come in black if that's your cup of tea.
Old May 16, 2012 | 04:07 PM
jslum's Avatar
jslum
Where can I get black ones? I've only seen Chrome. Anything special you had to do to mount them (rubber on the inside or anything like that?
