broken exhaust stud
Old May 16, 2012 | 07:42 PM
denimbob08's Avatar
denimbob08
Default broken exhaust stud
alright ive tried everything i can think of besides drilling it. that is my last resort. it is the forward most exhaust stud in the front head. ive tried stud removal sockets-not enough sticking out. ive tried turbo sockets-just spin after pounding them on. tried welding about 15 different nuts onto the stud and the only thing i do is break more of the stud off. anybody have another idea. i did borrow a Jims jig to drill it out but a drill is not gonna fit next to the frame to drill it. i am mentally exhausted and cant sleep just thinking about it.
Old May 16, 2012 | 07:51 PM
retxpres's Avatar
retxpres
Do a " broken exhaust stud" search on this forum. There was a similar thread started recently with quite a few post....
Old May 16, 2012 | 08:13 PM
sibur's Avatar
sibur
Don't know if you have room to try a small pointed punch. I've got some broken bolts out using this method when all else has failed.
Old May 16, 2012 | 08:24 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Like previously posted, give a pointed drift/punch a try, if that doesn`t work, you need to either find a way to drill it in place, or pull the head.
Old May 16, 2012 | 09:02 PM
lo-rider's Avatar
lo-rider
Take it to a pro.
Old May 16, 2012 | 09:09 PM
AFONE's Avatar
AFONE
Assuming its not sheered clean and there's something bite onto, Crank the bike up and let it idle and get hot. Once the bike gets hot, the metal expands and it'll be much easier to back out the stud.... That's how I got mine out.
Old May 17, 2012 | 06:44 AM
thedonthere's Avatar
thedonthere
Originally Posted by lo-rider
Take it to a pro.
+100!! I am getting my rear cylinder head back today. I broke an exhaust mount which in turn caused me to break both of the exhaust studs. I tried in vain to repair it myself with no luck.Took the head to a pro. $100.00 later and I'm ready to go.
Old May 17, 2012 | 10:25 AM
07bobber's Avatar
07bobber
I just replaced two on a revtech motor, the first two were easy but the front studs are gonna be a Bitch.
Old May 17, 2012 | 11:01 AM
retxpres's Avatar
retxpres
Is over tightening the number one reason for breakage? I bust installed a set of pipes and made sure I didn't over tighten. I did find that the 2-1 pipe was
a real tight fit though. Could this cause fracture?
Old May 17, 2012 | 11:07 AM
lo-rider's Avatar
lo-rider
Breakage is usually caused by lack of maintenance (accumulated corrosion) and improper technique (just cranking on the wrench til the stud snaps off) instead of first soaking it overnight (at least) in Aerokroil, then using heat/impact driver/etc to break the nut loose.
