TIP For Those Using DFOs and TFIs
Whiff
Do yourself a favor, heat shrink or electrical tape a nice layer around the length of your ground wire going to the battery.
Mine developed pinched or worn areas TWICE and was shorting out my bike and blowing fuses.
If you own one and your ECM fuse blows, this should be the first thing you check.
Whiff
mud
A month or so later, same thing began to happen. This time, however, I could see the tell-tale signs of an eventual fuse blow. Hitting the ignition would momentarily (and I mean for like a split second) bring the bike dark before eventually turning over. The readout on the speedo would look weird during the "dark" miliseconds. I would take the battery box off and futz with the DFO ground wire and that would take care of it...for a few days. Then it blew again.
I took a good look at the DFO ground again and found another spot where the casing had been worn away - probably from vibrations rubbing it along the area through which I had it routed. I taped the whole damn thing up and haven't had any problems since.
Whaddya think?
Whiff
Whaddya think?
Whiff
Whiff, a ground wire.......grounds. Period.
A bare spot on a ground wire.................just grounds more.
If that bare spot (on the ground wire) touches an energized, "hot", wire,
then you will have a short, resulting in a blown fuse.
A bare spot on an energized, "hot", wire,
can "ground", then you will have a short, resulting in a blown fuse.
mud
Any chance that wire from the DFO going to the negative terminal is anything other than a ground????
Whiff
Stupid question before I end up checking everything again (which won't happen until/unless I short out again)...
Whiff
Any wire to the frame or motor is a ground.
The negative battery, grounds to the frame. Frame to motor, etc and on and on.
And Yeah, don't check anything till it breaks.
Like they say -
"If it ain't broke don't fixit".
On the other hand, if you get bored,
"Work on it till it does break, then fixit".
mud
Whiff
Like they say -
mud
