Drivetrain whine?
Old May 26, 2012 | 05:16 PM
Wakko47's Avatar
Wakko47
Default Drivetrain whine?
While I was riding the bike this afternoon, I noticed that if I pull in the clutch and coast, I hear a whine coming from either under me or behind me a bit. Obviously it's hard to tell while cruising down the road at 50 mph. It's not the motor, definitely speed related vs. RPM related. Sounds closer to the tranny than anything else. Normal or should I be concerned? I just changed the fluid about two months ago or so, used Lucas gear oil, about 3/4 of a quart til indicated full on the jiffy stand.
Old May 26, 2012 | 06:20 PM
stilup's Avatar
stilup
Tranny takes a quart.
With the hot season I switched to 75W110 Amsoil
No noise and smooth shifts,
Old May 26, 2012 | 06:42 PM
Wakko47's Avatar
Wakko47
I filled until it was full, tranny cold. Is it supposed to be done hot?
Old May 26, 2012 | 06:45 PM
stilup's Avatar
stilup
Not sure on a 1996 but my 09 takes a quart.
Old May 26, 2012 | 06:49 PM
Wakko47's Avatar
Wakko47
My FSM says a quart too, but when it appeared to read full on the dipstick after the 3/4, I figured it had some residual fluid left inside. The dipstick is chrome, which makes it a bit harder to read with the fresh fluid, maybe I need to add more.
Old May 27, 2012 | 04:57 AM
OldMike's Avatar
OldMike
I use 75w90 gear oil like Royal Purple, my bike takes less than a quart when measured HOT with the bike standing straight up, not on the jiffy stand.
Maybe somebody will answer who actually knows your bike, I use a owners manual.
Old May 27, 2012 | 07:53 AM
stilup's Avatar
stilup
+1 on the owners manual
Changing tires and shocks other than stock will have different readings from the jiffy stand.
Are yours stock size?
Old May 27, 2012 | 08:53 AM
Wakko47's Avatar
Wakko47
I believe so. Shocks don't appear to be anything special, and sure as hell don't feel any better than stock.
Old May 27, 2012 | 11:22 AM
mang0's Avatar
mang0
Just changed mine last week, only took about 3/4 of the quart. I have
pirelli night dragon tires....would that make a big difference in fluid level as measured on dip stick..,?
Old May 27, 2012 | 09:29 PM
ackman1968's Avatar
ackman1968
The six speeds take a quart but it would be reasonable to expect the five speed to hold a little less.
FFHD05
Jul 19, 2012 11:50 AM
PKellyMc
Feb 23, 2010 06:12 PM
1Reaper
Jun 12, 2009 08:01 PM
haze324
Sep 22, 2008 07:14 PM
dstahl
11
Jan 19, 2008 07:26 PM
