Rattle when braking
Old Jun 1, 2012 | 11:58 PM
mondoe's Avatar
mondoe
Default Rattle when braking
Have been noticing a rattle while braking, was thinking it was coming from the fuel tank since the front thru bolt that secures it has excessive play. have attempted to insulate the bolt and retorque it but noise is still present. have 7k on bike and have not serviced forks or did fall away test yet. Notice primarily when using front brake. Any suggestions appreciated.
Old Jun 2, 2012 | 06:54 AM
LarryLives's Avatar
LarryLives
Front engine mount?
Try searching, there are a few threads regarding the rattle "vibration" of the bad front mount and while clutch in/braking...
Old Jun 2, 2012 | 07:09 AM
maddghost's Avatar
maddghost
Well buddy your tank should be nice and secure. Add washers if you have to, and check ther rear tank mount as well. Whole job is ten miutes. check your whole front end for anything loose including the heat shields...... in thos same ten minutes
Old Jun 2, 2012 | 09:14 AM
WVNightster's Avatar
WVNightster
Is it more of a buzzing sound?If it is it's from the brake rotor,air passes through the slots causeing a buzz like sound/feel.I was told this is normal when applying front brake.
Old Jun 3, 2012 | 10:12 PM
mondoe's Avatar
mondoe
Yes, tank is secure, will need to procure a bike jack to properly check front end, didnt notice anything loose on exhaust but will recheck.
Old Jun 3, 2012 | 10:14 PM
mondoe's Avatar
mondoe
Am familiar with sound your describing thats not my issue.
Old Jun 3, 2012 | 10:18 PM
mondoe's Avatar
mondoe
Think im gonna start with servicing the forks. Will update with my results, also gonna change front motor mount since its smoked. May take me several weeks to accomplish but will update with my results.
Old Jun 3, 2012 | 10:54 PM
macnab_sf's Avatar
macnab_sf
Gas cap? Drives me nuts.
Proline1969
May 29, 2017 08:25 PM
89FLHTC
EVO
Apr 15, 2016 06:55 PM
Steel Steed
Jul 8, 2012 06:05 AM
Andjh123
Nov 4, 2009 11:37 AM
Thornhammer
Jul 22, 2009 07:01 PM
