Check your top engine mount!
Old Apr 14, 2016 | 10:32 PM
89FLHTC's Avatar
89FLHTC
Default Check your top engine mount!
I had my fuel tank pulled up today while doing some wiring and thought I would check the tightness of my top engine mount while I was there. I was very loose! I thought it might have been worn out as I have been hearing a metal to metal vibration coming from under the tank. It was just a loose bolt. Might want to check yours while your there next time. FYI
Old Apr 15, 2016 | 05:19 PM
byronk's Avatar
byronk
Was the bike vibrating/shaking because of the loose mount or just making noise?
Old Apr 15, 2016 | 05:46 PM
89FLHTC's Avatar
89FLHTC
Just a rattle, mostly at idle. I can't tell if it's any smoother or not.
Old Apr 15, 2016 | 06:55 PM
Alienwulf's Avatar
Alienwulf
Found the same thing on mine the two lock nuts were backed of and I had been hearing a clicking noise. Thought it was a rocker or tappet it was the top motor mount. Will need to check mounts more often. Thanks for the heads up.
muaymendez1
Engine Mechanical Topics
Jul 21, 2017 08:55 PM
ftwflh
May 1, 2015 08:17 PM
Jeff's 1st Harley
Nov 1, 2014 08:35 AM
Don W.
Apr 10, 2009 09:14 PM
HENTER
Exhaust System Topics
May 27, 2008 10:11 AM
