Rough running sometimes TC -88
Old Jun 27, 2012 | 02:01 PM
skinless's Avatar
skinless
Default Rough running sometimes TC -88
Wondering if anyone has had this problem I'm experiencing. When motor is cool ( first 2 to 3 miles down the road ) The bike seems to hesitate for a split second and when that happens the check engine light comes on. The light go's off after a few minutes. Once this past weekend the bike actually shut off. I usually start the bike and let it run 3 to 5 min before I head out when the motor is cool. Just this afternoon heading back from lunch I was leaving the Hardees, I got out on the highway and started accelerating and it seemed to miss about 3 times. I have not pulled the plugs or anything yet because I'm still at work. Was hoping someone has had the same issue and might have some suggestions. Any advise is appreciated.
By the way the motor is stock with just the addition of pipes and air cleaner and never jetted. Only time motor has been broke open is to have cam bearings replaced. Motor has about 25,000 miles on it and is out of a 99 FXDX.
Old Jun 27, 2012 | 02:17 PM
OldTyme's Avatar
OldTyme
When I bought mine (01 FXDL) it was missing quite a bit , pulled & replaced plugs & all was better. Never got any check engine lights though.....
My $0.01 (wasn't worth $0.02) : )
Old Jun 27, 2012 | 02:27 PM
Good_Apollo's Avatar
Good_Apollo
Same here, and make sure the plugs you put in are properly gapped, this has caused misfires for me in the past too.
Old Jun 28, 2012 | 04:36 AM
skinless's Avatar
skinless
Thanks for the suggestion. Will change out today.
Old Jun 28, 2012 | 07:30 AM
cecharles's Avatar
cecharles
Get yourself a pair of Autolite Iridium plugs. (pt# XS4164). Will make a big difference. Gap is .040". You also see how the plugs are burning and you might have to rejett the carb.
Old Jun 28, 2012 | 08:52 AM
skinless's Avatar
skinless
Looked at J and P and seen them. Going to see if old Auto Zone has them.
Once again thanks guys
Old Jun 28, 2012 | 09:19 AM
rh8234's Avatar
rh8234
If you put on some pipes with less back pressure (louder) and a more free flowing air filter, you will definately need to re-jet. Also check for intake and exhaust leaks. When you changed the pipes, did you replace the manifold gaskets? Did the missing start after making one of the changes (pipes or AC)? Always check the last thing you worked on first.
Old Jun 28, 2012 | 09:56 AM
skinless's Avatar
skinless
Originally Posted by rh8234
If you put on some pipes with less back pressure (louder) and a more free flowing air filter, you will definitely need to re-jet. Also check for intake and exhaust leaks. When you changed the pipes, did you replace the manifold gaskets? Did the missing start after making one of the changes (pipes or AC)? Always check the last thing you worked on first.
The bike was fine after the installs of pipes and air filter 2 to 3 years ago. It has always been kinda hesitant on cold days. When I first bought the bike I brought it to get serviced and adjusted. The mechanic sad there so no need in jetting. Thinking this whole time it might need it. Last thing I did was remove exhaust and did replace gaskets. I have checked the nuts a few times and looked for leaks and nothing was found. Will check again because things do loosen up.
Old Jun 28, 2012 | 10:15 AM
CM22's Avatar
CM22
If it is not the plugs it sounds like a carb re-jet is what will be needed. I have a 2000 FXD and it likes to spoil the rear plug pretty often. I always carry an extra in the tool bag.
Codger
Jul 12, 2016 06:47 AM
Mr E
Exhaust System Topics
Jan 22, 2013 07:28 AM
missedem
Apr 11, 2011 04:59 AM
jcowan
Sep 14, 2009 01:51 AM
cwarrants
Jan 21, 2007 11:24 AM
