similar cams
Old Jun 30, 2012 | 11:20 AM
punkmxcn's Avatar
punkmxcn
Default similar cams
I know there are tons of threads about cams but I just need some opinions.
2010 FXD Stock motor, high flow air cleaner, RB Racing pipe... I'm weighing options on cams.
I have a sportster that runs SE 575s and when I jump on the Dyna it just doesn't seem to have the torque/power in the mid to high rpms. I know, I know... completely different bikes and builds.
But, is there a cam out there that will get me close? I want to go into head work and high compression pistons as of yet.
I tend to ride in upper rpms, don't know why, I guess to me it seems easier to slow the engine and easier to up shift for maneuvering.
Old Jun 30, 2012 | 12:21 PM
SC-Longhair's Avatar
SC-Longhair
If you want similar power then get a cam with the same/similar profile.
Old Jun 30, 2012 | 03:00 PM
JohnC FXDX's Avatar
JohnC FXDX
I saw Andrews makes a new TW57 cam. Supposed to be the same specs as the 37, but it has .560 lift. You will only get so much with a stock engine. A high rpm cam will be a dog without high compression and head work. The 57 should work well enough with a 96" and stock compression though. Would be better if it had a little more. Maybe use a .030 head gasket.
Ron C
Engine Mechanical Topics
14
Aug 10, 2019 03:14 PM
Sash302
May 30, 2009 08:32 PM
marinepilot81
Exhaust System Topics
16
Nov 14, 2008 09:53 AM
Fatboy931
EVO
Jul 23, 2007 10:29 AM
