Weird clunk after 1000 miles service
Old Jul 4, 2012 | 09:35 AM
ash uk streetbob's Avatar
ash uk streetbob
Default Weird clunk after 1000 miles service
I took my SB 12 in for its service the bike seems to running better if anything but one thing I have noticed is when its cold and I put it in to first I hear a different noise its always had a slight clunk but it sounds louder now almost like a vibration noise only thing i can compare the noise to id one of them springy door stoppers once its been in first gear once the noise goes away when i reselect first any tips
Old Jul 4, 2012 | 11:36 AM
MrPappagiorgio's Avatar
MrPappagiorgio
Did you switch to SYN 3?
Old Jul 4, 2012 | 03:02 PM
ash uk streetbob
Honestly no idea just let them do there thing I figured they would use the same oil
Old Jul 4, 2012 | 03:35 PM
J.Sizer's Avatar
J.Sizer
My 11 Wide Glide maked the some noise after the 1000 service. I believe it's just the difference between the break- in oil and the new oil. there is also the possibility of components in the transmission and clutch developing a little normal slack. I have paid good attention to this on my bike, seems to be a non issue, I only hear it when the engine is cold.
Old Jul 4, 2012 | 04:23 PM
nevil's Avatar
nevil
It doesn't sound like anything to worry about now. I would let the dealer know what you observed so it's on record. At least you're under warranty, so just be aware of any other changes.
Old Jul 4, 2012 | 07:21 PM
MrPappagiorgio
They may have sold you Syn 3. If so it make the transmission louder. If you switch to redline oil you will be presently surprised how much better the transmission shifts.
Old Jul 5, 2012 | 04:32 AM
ash uk streetbob
Thank for all the info seems to be nothing to worry about only thing I found what was strange is I had supposition that the clutch cable may be lose so when I selected first i pulled the cable a bit to test the tension whilst selecting first and the transition was smoother and quiter and one else tried this
Old Jul 5, 2012 | 06:44 AM
ynots's Avatar
ynots
The new cables will stretch.... How much play in your clutch cable? You should have 1/16-1/8th inch play at the grip. Does it quiet down when the bikes warm?
Old Jul 5, 2012 | 08:35 AM
J.Sizer's Avatar
J.Sizer
This thread Just reminded me that I never readjusted my new clutch cable from when I switch my bars to z bars( it's been about 1500 miles ago). So this morning I did a cable adjustment seem to be working about the same.
Old Jul 5, 2012 | 12:53 PM
Jr Bob Dobbs's Avatar
Jr Bob Dobbs
Here the same clunk on my 11 SB seems like it's louder when the engine is cold.
