How often?
Old Jul 16, 2012 | 01:13 PM
golfblues's Avatar
golfblues
From K&N............
4. How often do I need to clean my K&N air filter?
If you have not experienced a decrease in mileage or engine performance, chances are your filter is fine and does not yet need cleaning. To be more specific, the filter does not require cleaning if you can still see the wire screen on the entire air filter regardless of how dirty it may appear. When the screen is no longer visible some place on the filter, it is time to clean it. When used in normal paved road, street or highway conditions, our replacement air filters that fit in the factory air box should require cleaning every 50,000 miles and our large conical filters on an intake system should require cleaning every 100,000 miles. When used in dusty or off-road environments, our filters will require cleaning more often. We recommend that you visually inspect your filter once every 25,000 miles to determine if the screen is still visible.
Old Jul 16, 2012 | 01:22 PM
Dew Me's Avatar
Dew Me
WOW! That is pretty eye opening!!! I'll continue cleaning it more often than that though
Jim Kraft's Avatar
Jim Kraft
Yep! I clean mine at 50,000. It is still working fine at that point, but I go ahead and clean it anyway. They work much better if you do not clean them so much. I never understood why people clean them so often.
Old Jul 16, 2012 | 03:19 PM
Snydcat's Avatar
Snydcat
I've cleaned mine 1 time in 63,000 miles.
Old Jul 16, 2012 | 03:26 PM
rooti's Avatar
rooti
I'm telling you, I've used the K&N filters for years and unless they are a little dirty they don't filter very well.
Old Jul 16, 2012 | 03:34 PM
Dew Me's Avatar
Dew Me
OK, now here is a question: We keep on talking about cleaning, but what about adding oil? Even if I only clean it every 100K for example, I should still be applying the oil annually or more?
Old Jul 16, 2012 | 03:42 PM
rooti's Avatar
rooti
I think if it was oiled properly to begin with its good to go unless your seeing white mesh. I personally wouldn't wait for 100,000 miles
Old Jul 16, 2012 | 05:28 PM
FlatBlack12Bobber's Avatar
FlatBlack12Bobber
i have always re-oiled k&n's every 5k miles
slyedog
Apr 4, 2015 06:20 PM
29342
Jun 19, 2012 09:46 AM
Brawny MMC
Jun 2, 2011 12:28 AM
FLSTF
Exhaust System Topics
Aug 23, 2009 03:33 PM
bberck
Apr 13, 2009 12:03 PM
