This Is Why Companies Get Sued
Old Jul 20, 2012 | 08:12 AM
  #31
AllenW's Avatar
AllenW
Just curious as I'm thinking of buying one, do you need the lifting blocks with the J&S lift?
Al
Old Jul 20, 2012 | 08:22 AM
  #32
overhead's Avatar
overhead
Al
No. The jack is great, much more stable than the other jacks I have used.
Old Jul 20, 2012 | 08:28 AM
  #33
razors edge's Avatar
razors edge
are you guys aware of the wooden jack in the under fifty bucks section of this form? i use it and it works really well. so simple and extremily cheap.
Old Jul 20, 2012 | 08:34 AM
  #34
overhead's Avatar
overhead
Originally Posted by 11bDad
Is it a good design? No. Is it worth getting that worked up over? No. If he damaged his bike, or injured himself from not strapping the bike down, he should be pissed at himself for not using a little bit of common sense.
Again, I am not favoring suing anyone, but, in some instances (I do not think this is one) a company will not make a change that will cost them money unless *not* making the change will cost them money (lawsuit). It is sad, but that is the way of the world these days.
It is not just that the bike may fall if not strapped down. Once the blocks fail the bike is sitting on the jack or hanging half way off the blocks (like the pics I posted). Obviously, the extra room the blocks provided is needed to clear the oil pan, once the blocks fail that extra room is not there. Getting the bike off the lift is also a joy, let me tell you.
Old Jul 20, 2012 | 08:49 AM
  #35
icecaps's Avatar
icecaps
Reading More Posting Less
I believe the extra rail is there to protect the bottom of the engine transmission otherwise the pan would hit first. I know the I have scape marks on the bottom of that rail and I am thankful it was what took the hit.
While it is a PITA, if you can't deal with adjusting to it then you probably shouldn't be wrenching anyway.
Old Jul 20, 2012 | 08:51 AM
  #36
INJEKTER's Avatar
INJEKTER
i would not stack blocks on a jack then place the motorcycle on it unless the blocks were bolted down...that is an accident waiting to happen, i would however realign the lifting bars on the jack so that it worked for my bike or i would buy a jack that fit....those Harley blocks are freaking stupid.... i lift many heavy things at work and placing a larger heavier item on top of smaller stacked up items is not preferred...
Old Jul 20, 2012 | 09:27 AM
  #37
AllenW's Avatar
AllenW
Thanks.
Al
Old Jul 20, 2012 | 09:37 AM
  #38
Alleyn's Avatar
Alleyn
Just watched the video, on J & S's website... that's unbelievable, how they can rough-house the bike like that, in the air. I'm sold...
http://jsjacks.com/index.php/product...ycle-lift.html
Old Jul 20, 2012 | 09:59 AM
  #39
RicMF's Avatar
RicMF
I agree completely. I'm surprised Harley sells those blocks. I wouldn't be surprised however if some other company made and sold them. (But suing them? That's what wrong with this country...)
I modified my Harbor Freight jack and now it fits great, the bike is very stable when it's on the lift, and it was cheap and effective solution. I used a homemade block before I modified the jack, and it wasn't worth the risk or the time I spent wrestling with it.
In hindsight, If I had to do it over again I'd just buy the damn J&S jack right from the start. It would paid for itself many times over by now.
Old Jul 20, 2012 | 10:15 AM
  #40
Gommee's Avatar
Gommee
Devil's Advocate
Putting anything on a jack suspended in the air is "use at your own risk"!
Stupid is what stupid does.
A little common sense goes a long way!
I push my jack under my bike, place a small leveling block on the back side by the kickstand stop, jack her up. I have sufficient clearance under the tranny and clutch cable.
Bike does not move or wobble.
I STILL STRAP IT DOWN...FOR SAFETY!
As for the J&S Jack, it still looks like you need something to compensate for the offset Dyna frame. Correct me if I am wrong, but please explain.
