This Is Why Companies Get Sued
Old Jul 21, 2012 | 02:08 AM
  #61
Scaredofrain's Avatar
Scaredofrain
Originally Posted by dobro
My post was made because I am concerned about bikers who roll the dice with that "poorly designed tool". Just my opinions.
Anyone using a lift should be aware of the risks involved. Some people are not happy with the odds and will not use one. Others have decided it's worth it.
You find that the lift is not the correct tool for the job. That's your opinion and I respect you for it as it shows that you have thought about it. Where you go wrong is the assumtion that others are not in a fit state to make up their own mind about their safety.
A tool not appropriate for a specific job does NOT mean that is a poorly designed tool! I means that is not the correct tool for the job.
The user is responsible for correct use of a product NOT the company that makes them.
Old Jul 21, 2012 | 03:02 AM
  #62
nexeradg's Avatar
nexeradg
I'm slightly offended by the Chinese remark.
Old Jul 21, 2012 | 04:03 AM
  #63
Sling Blade 14's Avatar
Sling Blade 14
A geographical reference?
Like "American" "Japanese" "Mexican"?
Hmmmmm....
Old Jul 21, 2012 | 04:17 AM
  #64
rubberfrog's Avatar
rubberfrog
Don't be so sensitive. You're on a biker forum, not a ***** forum.
Old Jul 21, 2012 | 05:38 AM
  #65
TGWN's Avatar
TGWN
The OP does have a good point. He just delivered it like a lawyer or a sue happy guy. The funny thing is many of these posts people are looking for someone else to blame. These forums tend to become more attack then thought driven. With that being said, I had a floor jack and tried the blocks. It was very clear that this was stupid. I could tell there was very little if any thought put into the design. I'm betting the blocks idea was submitted under the "I have an idea" (or what ever that HD program is). I sold the jack and bought a table lift and a screw jack. Problem fixed.
Old Jul 21, 2012 | 07:10 AM
  #66
nexeradg's Avatar
nexeradg
My comment was intended to add a dash of humor to an otherwise 7 page flame-fest.
**Failed**
A "***** forum" does sound quite appealing though.
Old Jul 21, 2012 | 08:20 AM
  #67
dobro's Avatar
dobro
Originally Posted by Taddeoeg
On second thought, please drain all the fluids from your bike, rinse the engine and fuel tank with a non-flammable liquid, and then park it in your living room as a decorative accent. Riding is clearly far beyond your tolerance for risk.
When I start feeling stupid and want "risk" I'll get right to it and play Russian Roulette. To me, bike riding is all about exhilaration. The prospect of a 700 pound bike falling on me is not exhilarating, but different strokes for different folks.
Old Jul 21, 2012 | 12:59 PM
  #68
BluBob's Avatar
BluBob
Originally Posted by Alleyn
Just watched the video, on J & S's website... that's unbelievable, how they can rough-house the bike like that, in the air. I'm sold...
http://jsjacks.com/index.php/product...ycle-lift.html
I've had one for three years. While I have never tossed the bike around on the lift they way they do in that video, I have sat on it to adjust bars, ect and have rolled it around plenty. I have never gotten the feeling it was the least bit in danger of tipping either side to side to front to rear. Its a great jack.
Old Jul 21, 2012 | 01:01 PM
  #69
mud's Avatar
mud
Anybody who's tried jacking up their Dyna on a standard (expensive jacks avoid the problem) mc floor jack knows that the projection of the oil pan lower than the frame prevents it. You can buy blocks from HD to stick to the frame to level it out for the arms of the jack or you can make your own blocks or you can modify the jack. If you pick the blocks option you'll probably need to roll you bike onto 2x10's so the jack can clear the blocks. Using any of those options creates a very dangerous situation. There isn't any justification for HD putting our lives in jeopardy just to jack up a damn motorcycle. HD needs to warn owners not to attempt to use such jacks instead of encouraging it by selling the blocks. I doubt that even the Chinese are crazy enough to rig up such a half-assed method to lift a motorcycle. If you know anyone who's been hurt as a result of that situation do them a favor: tell them to see a good lawyer. Just my opinion.
Would the "correct precautions" consist of strapping an 8' long, 1' wide, 2' tall, 700 pound motorcycle, which is sitting on 2 1/2" high blocks, to a 30" long 14" wide jack then lifting that motorcycle 16" into the air? Is it sane to get under such a contraption knowing that a block could fail? If a block fails what is the probability that the elevated 700 pound motorcycle will remain upright? You're the genius--you tell me.
When my bike was in the air on those blocks I concluded it was an accident waiting for a place to happen so I lowered it and threw the blocks into the garbage can. Sorry to rain on many self-righteous parades, but my bike and I weren't injured at all. My post was made because I am concerned about bikers who roll the dice with that "poorly designed tool". Just my opinions.
a lot of bitterness there dobro.
glad to hear your made the choice to trashcan the lift adapters.
butt, I really don't get it.
I do believe the lift adapters would never fail if used properly.
I went through 2 sets over a several year period.
both delaminated after being used successfully many many times.
if you do not have the adapters FLAT they will fail.
if the weight is STRAIGHT down impossible to fail......
unless you apply significant sideways force (for example sledgehammering an axle out.)
that's my opinion.
00glider's picture...............
as for the lawsuit, I highly doubt anyone would get around the disclaimers that are in the instructions.
first two sentences....
This kit is designed for 1999 and later Dyna TC88 model motorcycles to be used with Motorcycle Service Lift (P/N94653-98)
and Motorcycle Cleaning Stand (P/N 94652-98).
Before using your adapter kit,
it is your responsibility to read and follow these installation and operating instructions
Old Jul 21, 2012 | 04:00 PM
  #70
ackman1968's Avatar
ackman1968
Originally Posted by WS6 Formula
To me he sounds like someone that actually works on his bike, and he does have a legitimate complaint.
Mine have come apart too butI still haven't had any issues. They aren't the perfect solution but when used with caution they do the job.
