Triple tree swap
Old Jul 21, 2012 | 03:49 AM
Limey's Avatar
Limey
Default Triple tree swap
I've finally collected the parts to put a wide glide front end on my Bob. Fat bob trees and a conversion kit from Hawg Halters.
Is this a straightforward swap, unbolt one and bolt up the other? Or is there anything more complex involved, I.e. is there any setting up involved with the steering head bearings?
Has anyone posted a step by step guide anywhere?
Thanks in advance
Old Jul 21, 2012 | 05:15 AM
p51bombay's Avatar
p51bombay
FB trees are a simple swap, head bearings are all the same and assuming yours are in good shape there's no need to change them, leave the races in place and swap the bearings to the FB trees but do clean and regrease them and get a service manual for the proper setup procedures and torque values.
Old Jul 21, 2012 | 05:17 AM
Limey's Avatar
Limey
Thanks, it was the setup procedures and torque values that was fishing for really....
Old Jul 21, 2012 | 05:54 AM
SuperFastGlide's Avatar
SuperFastGlide
plus youll need to set the fall away
Old Jul 21, 2012 | 06:01 AM
p51bombay's Avatar
p51bombay
Get a manual - best $60 you'll spend and you really shouldn't be doing a job like that without it.
Old Jul 21, 2012 | 11:24 AM
paullavery's Avatar
paullavery
Recently did the same, fat bob trees on my FXDC, pretty straight forward swap, took the opportunity to replace stock springs with the progressive drop in kit, you may need to change your wheel spacers on the axle depending on your hub, I was replacing wheels at the same time so had them build my front wheel based on the fat bob hub & just used stock fat bob spacers.
Love the look of the wider front end.
Old Jul 21, 2012 | 12:10 PM
Limey's Avatar
Limey
The Hawg halters kit comes with all the right spacers (I hope!) so the hub width should be fine.
Never heard of the "fall away", it's not like striped paint or a bucket of blue steam is it?
Old Jul 21, 2012 | 12:54 PM
ghostrider69's Avatar
ghostrider69
No, it is a procedure you use to adjust the preload on the neck bearings.
Old Jul 21, 2012 | 01:01 PM
Dirknar's Avatar
Dirknar
you MUST set the fall away and do it correctly.. If not you will get a wobble in your front end.. People have wrecked because of this wobble..
Old Jul 21, 2012 | 04:28 PM
Limey's Avatar
Limey
Fair enough, I'd never heard of that before. I knew the bearings needed adjusting but not heard of that test.
Odelay
Jul 21, 2014 10:26 PM
mturner2003
Feb 3, 2014 06:40 AM
BluBob
Aug 27, 2012 08:48 PM
nkauf21
Jan 28, 2012 04:53 PM
mrthinkshesfunny
Apr 17, 2008 01:30 PM
