Problem Shifting
Old Jan 17, 2007 | 11:28 AM
cwovp's Avatar
cwovp
Stage III
Default Problem Shifting
I have a 2000 Dyna Superglide Sport. Yesterday I removed the outer primary, compensating sprocket, and clutch hub to seal the primary-to -transmission mounting bolts because I had a leak. I got everything torqued down and put back together and went for a test ride. She shifted into first thru fifth no problem, when I went to down shift it was extremely hard to get back down to first. With the engine running and the clutch engaged I can't shift to neutral or second. The clutch seems to be disengaging the transmission, I don't understand why I'm having this problem. At first I thought I had the clutch adjustment way out of wack...I adjusted it per the manual and I still have a problem. Does anyone know what I missed and/or screwed up?????
Jim
Old Jan 17, 2007 | 04:14 PM
stubby's Avatar
stubby
Default RE: Problem Shifting
Usually if you take something apart and it ain't working right when put back together you did something wrong. But, I had a problem with my 06 glide not wanting to downshiftand not wanting to go into nuetral or first. There is a rodfrom the clutch throughthe primary into the tranny. It had rusted from lack of lubricant. Just an idea.
Old Jan 19, 2007 | 02:02 AM
R Racing's Avatar
R Racing
Do you have foward controls or mids? If you have Mids ,Maybe something is binding in the shaft that goes thru the primary cases?
Old Jan 20, 2007 | 02:00 AM
mtnlvr's Avatar
mtnlvr
Is your primary chain adjusted properly?
Old Jan 20, 2007 | 05:02 PM
Dick Johnson's Avatar
Dick Johnson
Did you have any trouble re-assembling.....might have bent a shift fork in the process
Dick
fxdx-fxr-xlh
Jun 29, 2018 04:49 AM
oldbuck
General Topics/Tech Tips
Mar 12, 2016 09:33 PM
tonebone_79
May 19, 2014 10:03 PM
rquest
Dec 7, 2012 04:12 PM
myzen
May 11, 2008 01:38 PM
