So..... I did this wide glide conversion, went pretty smooth, used the Arlen Ness kit and a demon headlight.... Just a question though, I kept the stock 19" front wheel, and my triple trees had stock rake, is it supposed to ride a little different? I mean I don't hate it, it just feels different????
Did you use your stock forks? Is there any rake in the trees? If you have stock length forks and didn't change the rake the I would check and make sure your neck bearings are adjusted correctly.
Looks like you've got an '05-earlier FXD with the 39mm fork tubes ...
Nice looking bike ... good work ...
Was there a spacer between the hub and the disc on the left side of the wheel ...? If so, the wheel should not be off-center ... You should have been able to tell if it was off-center when you were installing the kit ...
If everything went together solid, there should not be much difference in the feel of the front end ...
Did you have the ape hangers on your bike before you did the Ness Wide Glide kit ...? I'm wondering if maybe you weren't accustomed to the difference in the bars ...?
Assuming there was nothing wrong with the install, hopefully it is just a subconscious thing that will go away once you get used to riding it with the new configuration ...
I had he apes prior, I used the stock tubes, the kit had the rotor spacer and axle spacer. I did have to buy a new neck bearing as my old one was seized on the triple tree. There is NO pinch bolt upper neck bearing adjuster like on the stock tree. What it does have is a thin nut and it's threaded at the top of e tree. When the tree goes in from the bottom, you thread down the nut on top of the bearing and the dust cover, then you place the top tree on and secure it wih a huge hex screw to the top of e stem.
I'm thinking I could have possibly mixed up the axle spacers and have them on the wrong side, I'll try that today. I'm also going to tighten up that thin nut on top of e stem over the bearing and dust cup. Is it possible to over grease the neck bearings????
And now that I think of it, when I bought the new lower neck bearing, it didn't need to be pressed on, it just slid right on with the tiniest of tolerance. Perhaps that tiny slop in the neck beating extrapolates to a huge handling issue. At speed, the bike tracks just fine, at slower speed I'm constantly correcting
Changed bearings on my 06 WG and slid right on, not pressed...
I have the mini apes, and no steering issues at all. In fact I can ride no handed forever if I wanted to....
Sounds like your off center somewhere, or wheels outta balance.
Also make sure your tubes are both even and at the same height, and that you have the same amount of oil in each side. jmo....
