condensation in speedo
Old Aug 3, 2012 | 11:04 PM
jasfromnz's Avatar
jasfromnz
2nd Gear
Default condensation in speedo
anyone know how to get rid of condensation in speedo window??
Old Aug 4, 2012 | 12:49 AM
p51bombay's Avatar
p51bombay
A small hole drilled on the back (bottom) side if the case will allow the moisture to escape and dry out.
Old Aug 6, 2012 | 02:01 AM
Gommee's Avatar
Gommee
Devil's Advocate
My Speedo and gas gauge does it. HD told me I should not pressure wash it. I told them I only hand wash it!
When they did my major service and washed it, surprise, both were full of moisture! I asked them to warranty both of them because when the sun hits them, the underside is so badly filmed, you can not see through them.
Their reply: "we don't warranty fogged speedos" and it was from pressure washing it! Even after I showed them the moisture after THEY washed it.
Old Aug 6, 2012 | 03:36 AM
sfmichael's Avatar
sfmichael
Never tried it but it sounds like a good idea
Old Aug 6, 2012 | 07:51 AM
_Gir_'s Avatar
_Gir_
Also blow drying the bike dry can cause this.
Old Aug 6, 2012 | 08:04 AM
RAWHIDE07's Avatar
RAWHIDE07
I never pressure washed mine and it always fogged no matter what. I solved the problem by replacing it with a far superior Dakota Digital combo tach/speedo. No more fogging.
Old Aug 6, 2012 | 09:38 AM
scaldwellk's Avatar
scaldwellk
That is sweet. What did that set you back? Where did you get it?
Old Aug 6, 2012 | 10:11 AM
blueangel73's Avatar
blueangel73
I can tell you this much, the pressure washer theory is total BS. I have have my bike for two and a half years and it has only been washed twice (both times by the dealer). I ride my bike far to much to wash it. I do wipe it down with Harley Gloss at least once a week. The bike does spend a majority of the time outside because I ride it rain or shine. The humidity here in MD is really high, when I walk out to my bike in the morning I often have to wipe my seat down because it is covered in water. The same is said for my speedo. Sometimes the speedo will have the fog your talking about then, sometimes I don't get it until I am leaving work and themps outside are 95+ with no rain around for hours or days.
So unless the gage is made as a pressure tight device, like a diving watch, moisture is going to fine its way into anything and you will end up with the fog.
Old Aug 6, 2012 | 10:15 AM
RAWHIDE07's Avatar
RAWHIDE07
About $350 or less from various vendors,I bought mine last year factory direct from Dakota. It incorporates all your current features and adds several more.
http://www.dakotadigital.com/index.c...rod/prd684.htm
Old Aug 6, 2012 | 10:50 AM
YeOldeStonecat's Avatar
YeOldeStonecat
Most of 'em do it....put the bike away damp it will fog, wash it it will fog, ride in the rain it will fog. Temperature changes it will fog.
...but it goes away too.
