floor boards
Old Aug 11, 2012 | 11:00 AM
RonnR's Avatar
RonnR
I liked these...
untill I Fabed a mount for these.
Old Aug 11, 2012 | 01:10 PM
Harley Tim's Avatar
Harley Tim
Originally Posted by blueangel73
Thanks, pics look good. Doesn't look like I will have any issues using the Switchback set up on my bike.
Do you have a link to the thread where you list the parts needed?
Are you hppy with the detach bags? I have thought about adding them as well, seeing as to how my past bag was distroyed a few weeks ago.
Detach bags are the $hit in my book! I have the docking stations set up to accept those, and a sissy bar w/ rack. so, I can switch to 2-up in about 5 min. or less. When I get to where I'm going... I pop off the bags, sissy bar, and windshield, leave them in my tent, room, ect. and putt around "bare bones".... works for me. Plus I have room for rain gear, extra cloths, food drink, and such.
Here's a list with some notes to do the foot board job using Switchback parts.
Here's another little tid-bit to get you going.
Originally Posted by Harley Tim
OK, here I go,
I't's taken about a month to get in all the parts but, I think the wait was well worth it. These are for the '12 FLD footboards and, the people I hang with say " They look like they've belonged there all the time."
Here 's a list of P.N.'s and prices as they applied to me, having an'06 Superglide W/Fwd controls and Vance & Hines Bigshot exhaust.
For the footboards:
54165-12 SUPPORT, right footboard $ 52.72
54172-12 SUPPORT ASSY, right footboard $ 68.75
54173-12 SUPPORT, left footboard $ 52.72
54174-12 SUPPORT ASSY, left footboard $ 68.75
50621-06 FOOTBOARD ASSY w/pads $ UNK (See note #3)
50614-06 PAD, footrest $ UNK (See note #3)
7354 LOCKNUT (4) $ UNK
50674-05 BOLT, shoulder $ UNK
4512A SCREW $ UNK
For the brake:
38157-12 BRAKELEVER ASSY $ 111.00
42416-06 PAD, brake pedal $ 4.25
4997 SCREW $ 4.00
38160-12 CAP, brakelever $ 10.95
38161-12 PUSH ROD $ 72.56
42665-03 PIVOT SHAFT $ UNK. (See note #1)
For the shifter:
33789-12 SHIFT LEVER $ UNK. (See note #2)
34887-06 SHIFT ROD $ UNK. (See note #2)
6702 WASHER $ UNK (See note #2)
7736 ACORN NUT $ UNK. (See note #2)
If you have mid-controls:
2882W BOLT $ UNK (See note #4)
7710W NUT $ UNK (See note #4)
34639-93 RETAINER $ UNK (See note #4) For ’96-’00 models
34639-01 RETAINER $ UNK (See note #4) For ’01 and later
34640-93 COVER, Shift shaft $ UNK (See note #4)
3231B SETSCREW $ UNK (See note #4
NOTES:
#1; If HD Fwd controls are already on the bike, the existing part is the same P.N
.If NOT HD Fwd controls, OR is HD mid controls, this part may be needed.
#2; These parts are needed if the bike has mid controls. If HD Fwd controls are already on the bike, these parts are not needed.
#3; These are Stock FLD (Chrome) footboards and come with the PAD, I Opted for P.N. 51322-08 FOOTBOARDS (Black) from the ’12 HD custom book (I’m not real big on chrome) and my parts guy gave me a set of stock “take off” standard PAD, footrest.`
#4; These are parts listed as an option to removing the outer and inner primary cases to remove the existing shift lever shaft and, cap the holes.
Best wishes....Tim(HT)
__________________
RVN'70-'71(Rattler501/Firebird117) ,USA,RET '06 FXDi Super Glide with lots of stuff.
It's not rust.....It's patina!
Hope this helps,
Old Aug 11, 2012 | 04:57 PM
blueangel73's Avatar
blueangel73
Here is what I managed to put together for my list.
Everything for the footboards except the actual Footboard Pans and Inserts
4512A Screw (8) $1.10 ea
50674-05 Bolt (4) $1.65 ea
7354 Nut (4) $1.10 ea
54165-12 R Footboard Support $39.54
54172-12 R Footboard Support Assembly 54.81
54173-12 L Footboard Support $39.54
54174-12 L Footboard Assembly $54.81
Total Cost $208.50
33708-94 Bearing Sleeve (2) $2.20 ea (Thispart is in the Drawing in the book, but you did not list it, ???)
Total Cost $4.40
Everything for the Brake
38161-12 Brake Push Rod $54.42
4997 Screw $3.52
38160-12 Brake Lever Cap $8.76
38157-12 Brake Lever Assembly $83.25
42665-03 Pivot Shaft $9.20
Total Cost $159.15
Total cost for everything above is $372.05 Seems like a good price for a stock setup before you use whichever pans, pads, inserts and Shift pegs you go with.
Now I am thinking I will be going with the HD tribal theme
51060-08 Swept Wing Black Rider Footboards $62.87
Tribal Rider Footboard Insert – Swept Wing $78.60
Tribal Shift Peg $23.96
Tribal Large Brake Pad $31.96
Bringing my total cost to convert from my forward controls to Floorboards will be $569.44
I will take the stock parts you listed and get prices on tem to see how much they would change the price and post the difference when I have a chance.
Old Aug 11, 2012 | 09:35 PM
jjwaller's Avatar
jjwaller
RonnR
Really like your setup. However I don't have the fabrication capabilities. Like what i see in the first pic also. Which ones are those? Where they bolt-on?
Thanks
Originally Posted by RonnR
I liked these...
Old Aug 11, 2012 | 11:30 PM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
Total Cost $208.50
Total Cost $4.40
4997 Screw $3.52
Total Cost $159.15
Check the prices on Surdyke. I saved a bundle.
The bearing sleeve is already installed in the other part I believe.
Old Aug 12, 2012 | 06:15 AM
RonnR's Avatar
RonnR
Originally Posted by jjwaller
RonnR
Thanks
They're Kuryakyn's passenger boards, (Part #7906)
Simply bolt on to your stock peg mounts.
Kind of pricey, but I found a great deal on these from e-Bay.
Old Aug 12, 2012 | 03:40 PM
snstiggy's Avatar
snstiggy
Wyatt makes a floorboard setup. Its about $400. A lot of members seem to like it. It's made for the Dyna and bolts up, and is a complete package.
Old Aug 13, 2012 | 08:33 AM
blueangel73
So here is an update to all the parts pricings I could locate using HD, New Castle HD and Surdyke.
Looks like New Castle is the only vender that has all the part able to be ordered from their website come complete the change without having to go through mulitple venders.
(Qty Needed)
HD prices in this color
New Castle prices in this color
Surdyke prices in this color
4512A Screw (8) $1.40 ea / $1.10 ea / N/A
50674-05 Bolt (4) $2.10 ea / $1.65 ea / N/A
7354 Nut (4) $1.40 ea / $1.10 ea / N/A
54165-12 R Footboard Support $49.95 / $39.54 / $42.18
54172-12 R Footboard Support Assembly $69.95 / $54.81 / $55.00
54173-12 L Footboard Support $59.95 / $39.54 / $42.18
54174-12 L Footboard Assembly $69.95 / $54.81 / 55.00
50621-06 Footboard Assembly w/ Pad (2) N/A / $63.49 / $67.73
Total Cost $275.00 / $335.48 / $329.82
33708-94 Bearing Sleeve (Unsure if this needed or not) (2) $2.80 / $2.20 ea / N/A
38161-12 Brake Push Rod $68.95 / $54.42 / $58.05
4997 Screw $4.47 / $3.52 / N/A
38160-12 Brake Lever Cap $10.95 / $8.76 / $8.76
38157-12 Brake Lever Assembly $105.95 / $83.25 / $88.80
42665-03 Pivot Shaft $11.95 / $9.20 / $9.23
42416-06Large Brake Pad N/A / $3.40 / N/A
Total Cost $202.27 / $162.55 / $164.84
Total cost of complete change over to stock Floorboard setup fond on Switchback.
$451.87(*) / $502.43(**) / $494.66(***)
NOTES
(*) TOTAL COST IS MISSING COST OF SOME PART NUMBERS NOT FOUND FROM HD
(**) ALL PARTS WHERE LOCATED WITHIN THE NEW CASTLE HD WEBSITE
(***)TOTAL COST IS MISSING COST OF SOME PART NUMBERS NOT FOUND ON SURDYKE WEBSITE
Last edited by blueangel73; Aug 13, 2012 at 10:10 AM. Reason: Update to stock Floorboard requirement of two needed at listed price because their not sold as a set.
Old Aug 13, 2012 | 09:23 AM
nkauf21's Avatar
nkauf21
(Qty Needed)
50621-06 Footboard Assembly w/ Pad (not sure if this is for a set or each side, awaiting email to confirm, price could double if per side)
Total Cost $275.00 / $271.99 / $262.09
$451.87(*) / $438.94(**) / $426.93(***)
NOTES
That is a great list, thanks for doing some all of that research. I am also thinking about making the switch but I was only looking at Surdyke and the hardware p/n's weren't coming up on their site. If I do go through with this I'm going to go with the black half moon pans from the crossbones like Muddyape did and just go with the factory rubber inserts, rubber brake pedal pad and rubber shifter peg.
Old Aug 13, 2012 | 10:16 AM
blueangel73
I made this list to give people numbers to look at mainly. Where you see "N/A" under the Surduke colors (red), those part numbers don't show up, as you said, on there web page.
I plan on also going all black and plan on using the Swept Back board and the Tribal insets, I also plan on converting the rears to floorboards and using the FHLX swept back pans (after I have the FHLX removed and maybe having FXDB put in place of it.) total cost is around $900 through New Castle HD, but I am friends with my local dealer GM and I am going to see if he will match the cost so I can avoid S/H cost.
