Sealed Beam?
Old Aug 17, 2012 | 07:07 PM
Alleyn's Avatar
Alleyn
Default Sealed Beam?
The stock headlamp on my 2011 Street Bob is terrible. I've already replaced the bulb with a better Silverstar, but that doesn't eliminate the shadows and low cut-off that leave me blinded past 100 ft.
Is it possible to replace the lense and reflector with a 5-3/4" sealed beam unit?
I found this at J& P...
http://www.jpcycles.com/product/310-075
I should say that LED's and such, are out of reach for me.
Old Aug 17, 2012 | 07:35 PM
p51bombay's Avatar
p51bombay
Sealed beam lamps will give much worse performance than what you have now - you can install a higher wattage bulb but there is a risk that the added current draw could blow fuses, melt wires or even cause a fire. I would save up for an LED, you can get them online at about $320
Old Aug 18, 2012 | 09:30 AM
Austin Dave's Avatar
Austin Dave
Might the solution be to add an Auxiliary lighting kit? The H-D kit I added can use either Halogen bulbs or sealed beam lamps. The Halogen bulbs themselves are replaceable where the SBs are not. You can aim the aux lights too.
Old Aug 18, 2012 | 11:13 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
My `89 Softail came stock with a sealed beam, It was like riding blind at night...
JCBGlide
2014-2024 Touring Models
Aug 18, 2016 10:04 AM
asahi1234
Jun 25, 2012 10:11 AM
Hondo65
Jun 14, 2011 11:44 AM
roadking71865
May 12, 2010 12:16 PM
harleybob
Feb 5, 2006 04:27 PM
