High speed wobble
Old Aug 27, 2012 | 01:19 AM
JaronB's Avatar
JaronB
True track or spruthe is next on my list. Everybody that has done this that I know say it was the biggest noticeable mod they have done.
Old Aug 27, 2012 | 04:07 PM
dsbfxdwg's Avatar
dsbfxdwg
I recently had a very similar experience and found it to be loose spokes in the rear wheel causing the bike to wobble. Had the wheel trued and the issue is gone.
Old Aug 27, 2012 | 04:14 PM
RoadLord's Avatar
RoadLord
Did you put the nut on your top stabilizer mount?
Old Aug 27, 2012 | 05:44 PM
128auto's Avatar
128auto
Front end vibration is the hardest thing to diagnose, my friend's 08 dyna shakes like hell at 70mph, she can't even hold the handlebar, yeah 16" ape she has. I have adjusted head bearings, wheel hi speed balance, ride height etc. Still doing it, I have no idea. Btw she has mag wheels not laced.
Old Aug 27, 2012 | 05:58 PM
JRK5892's Avatar
JRK5892
as said you need to go one by one to get to the bottom of it... start with tires... an trick is if you feel it in the front chances are the issue is in the rear... if i can help at all let me know.
tires, alignment, forks, shock settings, motor mounts, wheel balance, wheel not true, bearing rub, sacked out fork springs
Old Dec 9, 2012 | 06:31 PM
leafman60's Avatar
leafman60
This may be a long shot for folks with a high-speed wobble but check your motor mounts, especially the top mount under the tank. The bolts for these can loosen or back out and allow the motor to flop around and make the bike wobble at speeds.
Old Dec 9, 2012 | 07:00 PM
aces&8s's Avatar
aces&8s
I think sometimes if ya might have weak shocks could cause an out of ballance bobbing effect.
Old Dec 9, 2012 | 09:28 PM
DanDman's Avatar
DanDman
I had a front end wobble at 80+. I had put on a 1/4 fairing when I first noticed it. I only had the bike a short time and never went over 70 before I installed it. I put on new rear tire the other day and it's gone now. I also changed my front rotors. I think it was the tire that stopped it.
Old Dec 10, 2012 | 06:36 AM
leafman60's Avatar
leafman60
Originally Posted by SteveO-ll
I had to reset my fork tube height after I changed my rear shocks in order to get proper trail. It took three slight incremental adjustments to get it right. I have buried the speedometer several times with no wobble, although it was only for testing, as I do not like riding that fast on open roadways.
So my suggestion would be to double check your trail to see if it is in tight specifications. I forget off hand what the actual measurement is. The tubes stick up about 3/8" above the top triple tree, even if they are not flush like some people like for looks, it does not look bad, and it settled my front-end problems.
The angle of the front forks relative to level as they extend to the ground determines rake and trail. Greater rakes and trail makes for greater stability. Less rake and trail makes for quicker steering. It's a trade-off determined by the purpose of the bike.
The rake/trail measurement can be altered by either changing the steering head angle as welded to the frame OR by simply raising or lowering the front of the bike relative to the rear.
In actuality, dropping the fork tubes so their tops are flush with the triple clamp, results in slightly more rake and trail since the front end is angled higher in the air relative to the rear. This results in more straight-line stability at the cost of slightly heavier steering. All other things equal, this should not cause great wobble propensity.
If you jack-up the rear end with taller shocks for more cornering clearance, lifting up the front end will work to preserve the height of both front and rear and preserve the original handling characteristics.
I put taller Ohlins shocks on my rear that lifted it about an inch. This has the opposite effect of raising the front. It makes the front lower relative to the rear and quickens steering. I dropped my front tubes to flush to help balance out the height of front and rear.
A severe high-speed wobble is likely casued by something else. Check your motor mounts all around for tightness. Check steering head bearing tightness. Maybe check spokes. (Maybe tires.)
Also, check wheel alignment. (Level the frame with a level and then check the rear wheel brake rotor with a level for perfect perpendicular with frame level. Check rear wheel straightness by measuring axle ends from hole in bottom of swingarm or with a laser level to front wheel.)
Mine had a 30-40 mph low-speed wobble that was fixed by my replacing the cheap stock Harley chinesee bearings with Timken/Fafnir bearings from a local supply house. Use Timken/Fafnir 205PP .
https://www.hdforums.com/forum/dyna-...el-wobble.html
With a Sputhe suspension stabilizer kit, mine now corners in competition with my european bikes. Amazing.
DynaJ
Oct 25, 2012 07:31 AM
ghoticov
Aug 22, 2012 05:48 PM
jmltinc
EVO
26
Jun 14, 2011 02:31 AM
flynavy
May 7, 2008 12:12 PM
Vitt
Sep 20, 2007 08:20 PM
