cam advice needed
Old Aug 28, 2012 | 04:18 PM
oakspeed's Avatar
oakspeed
Default cam advice needed
i have a 96" dyna wide glide. 2010.
it has SE ventilator air filter with K+N filter,
and V+H big shots. also has SERT tuner, with map downloaded to suit the above.
i dont want to go bigger with CC, and im just looking for a cam change to give me more low/mid range oomph.
i do most of my riding in urban areas, with some motorway, dual carriage way riding. on a run, generally keep it pegged to 80 mph.
so, for those of you that are clued up on these things, what cam should i fit,
or is it of no real use for what im after???
would a gearing change be more beneficial??
many thanks for your help.
Old Aug 28, 2012 | 04:32 PM
Good_Apollo's Avatar
Good_Apollo
Off hand, I would say Woods TW-222 or S&S 583
Old Aug 28, 2012 | 04:55 PM
kmontague's Avatar
kmontague
The se255 cam will give you a good low end to mid boost.
Old Aug 28, 2012 | 04:57 PM
RoadLord's Avatar
RoadLord
I like the SE 258 cams... makes it nice and rumbly:-)
Old Aug 28, 2012 | 05:03 PM
crazyanimal's Avatar
crazyanimal
I will be doing cams in my 2011 superglide next year and the dyno tech told me to go with se 204 cams and adjustable pushrods,he said they are an under rated cam and would produce a nice mid range boost,he said I wouldn't be disapointed
Old Aug 28, 2012 | 05:05 PM
128auto's Avatar
128auto
Fuelmoto is busy testing the new TW-222, they claimed low/mid range TQ/HP, I would wait a bit until they dyno a few and get some results. I can't wait so I ordered the TW-555 for my stock 96, stay tuned!
Old Aug 28, 2012 | 05:17 PM
RoadLord's Avatar
RoadLord
I've had SE 204 cams and they're not bad at all, very nice cam set up indeed!
RET_SCPO
Milwaukee Eight (M8)
14
Oct 15, 2021 03:45 PM
Jarhead1
2014-2024 Touring Models
15
Sep 29, 2017 10:15 AM
Alamomann
Aug 20, 2014 03:09 PM
Shirkey
Feb 27, 2012 09:33 PM
Sancho
Exhaust System Topics
Mar 18, 2010 05:04 AM
