Dyna Super Glide spring preload adjustment
Old Aug 29, 2012 | 06:18 PM
RobertV's Avatar
RobertV
4th Gear
Default Dyna Super Glide spring preload adjustment
Hello,
I have a 2007 Super Glide and I recently installed a lowering kit on the back. The preload on the rear shocks is set at 5 and my wife and I did a bike run on Sunday and we bottomed out a few times. I noticed two scratches on my upper belt guard. Do I now need to install different shocks??
Thanks for your reply
Old Aug 29, 2012 | 07:10 PM
hboat's Avatar
hboat
I'm not an expert on M/C suspensions, but I'd be careful. I had 11.5" Progressive 440's on my bike. I ride solo and I ride twisties pretty hard, but I'm 170 #'s. I used to bottom out occasionally and then I broke an upper shock bolt 40 miles from home. I had a very scarey ride home w/ my imagination playing out every scenario of breaking one on the other side. I've since gone w/ 12.5" 440's. With the extra inch of travel, I can loose pre-load for a ride that has initial softness but the shocks firm up when required. Haven't bottomed out since making the change, and that makes me very happy.
Old Aug 29, 2012 | 07:12 PM
DCLXVI's Avatar
DCLXVI
Removing the lowering kit will solve your problem.
Old Aug 29, 2012 | 08:51 PM
Austin Dave's Avatar
Austin Dave
Curious to know why install a lowering kit?
Old Aug 29, 2012 | 09:09 PM
nevil's Avatar
nevil
Or just ride solo. Can't have your cake and eat it too.
If you bottomed out you should look at the wiring under the back fender to make sure you didn't rub or break anything.
Old Aug 31, 2012 | 09:11 AM
RobertV's Avatar
RobertV
4th Gear
I lowered it because my wife wants to ride it and her feet were not flat on the ground. Now it's easier to move around and it actually feels lighter because it's lower.
Old Aug 31, 2012 | 09:14 AM
RobertV's Avatar
RobertV
4th Gear
Thanks, that's probably why my right turn signal doesn't work anymore!
Old Aug 31, 2012 | 09:37 AM
Austin Dave
ok, thanks. Prolly could have changed the seat without having to muk around with the suspension and gotten the 'lower' foot result. There is always the safety aspect to consider with changing the suspension. Hope everything works out ok.
Old Aug 31, 2012 | 09:38 AM
RobertV's Avatar
RobertV
4th Gear
Thanks for your suggestion!
Old Aug 31, 2012 | 09:41 AM
RobertV's Avatar
RobertV
4th Gear
Thanks Dave,
I think I will take a ride to the Harley shop to see what they recommend today.
JayFan
2014-2024 Touring Models
28
Sep 24, 2022 03:07 PM
xjayx
Sep 24, 2011 02:27 PM
Yldtang
Mar 9, 2010 02:54 PM
BrendanGTStang
May 8, 2007 09:16 PM
Randy Page
Feb 24, 2006 04:14 PM
