Quiet Please!
Old Sep 3, 2012 | 10:51 AM
Scooterman26255's Avatar
Scooterman26255
Stage I
Default Quiet Please!
I have a '91 dyna wide glide.
In the past I had installed edlebrock heads and higher lift cam and am currently running "hotshot" straight pipes. The bike has a really obnoxious "crackle". I want to make it quieter without losing all the performance. My pipes have a "baffle" but they do nothing. Do I have to go back to factory mufflers or is there something in-between?
Help!
Old Sep 3, 2012 | 10:58 AM
oaken1's Avatar
oaken1
I aint real sure...but from what I was just reading in another thread.....perhaps you can install a set of those "Q" TTI's.....apparently they add low end torque while also lowering decibals..
Old Sep 3, 2012 | 11:46 AM
p51bombay's Avatar
p51bombay
Get a 2into1 - better performance, less noise, more ground clearance.
Old Sep 3, 2012 | 12:10 PM
nevil's Avatar
nevil
+1
Probably your best bet to make the bike run and sound better. If budget is an issue you can set a pair of Cycle Shack slipons for about $150. Great sound and will give you better low and mid-range performance.
Old Sep 3, 2012 | 01:36 PM
dirtdreamer50's Avatar
dirtdreamer50
May want to check with Big City Thunder about their baffles and thunder monsters. They do work well for their intended purposes. tomp dd50
lombo
Feb 14, 2008 03:26 PM
exhuman
Jun 8, 2006 09:35 AM
Delmar
Exhaust System Topics
Jun 5, 2006 01:26 PM
Hoopman
Jan 4, 2006 06:47 PM
Ram
Dec 14, 2005 10:46 AM
