Stock Dynas: Curious what speed you up shift?
Old Sep 17, 2012 | 07:01 PM
BKSinAZ's Avatar
BKSinAZ
Default Stock Dynas: Curious what speed you up shift?
To all stock Dynas, just curious what speed you shift gears at... (Not RPM)
This is my first Harley so I am curious if all Stocks are about the same. On my new 2012 Super Glide 96..
I Shift from 1st to 2nd @ about 15 mph
2nd to 3rd @ about 30-35 mph
3rd to 4th @ about 45 mph
4th to 5th @ about 55 mph
5th to 6th @ about 65 mph
Is this about what you all shift? Don't get me wrong, I do listen/feel the revs and attempt to shift correctly, but I am just curious if this falls inline with other stock Dynas.
Old Sep 17, 2012 | 07:04 PM
Shredding rubber's Avatar
Shredding rubber
I shift on my 08 about 5mph higher across the board.
Better a few extra rpm then potentially lug the engine.
Now that I've got it cammed and 106 I stay in 3rd til 50mph until I see enough open road to shift into a higher gear to cruise
Old Sep 17, 2012 | 07:06 PM
rubberfrog's Avatar
rubberfrog
You shift way too early. At 55 I'm still in 3rd.
Old Sep 17, 2012 | 07:07 PM
BKSinAZ's Avatar
BKSinAZ
Are you stock or upgraded?
I am speaking of stock.
Old Sep 17, 2012 | 07:11 PM
rubberfrog's Avatar
rubberfrog
Stock 103
I like to stay in the power band until I get to cruising altitude.
Old Sep 17, 2012 | 07:15 PM
BKSinAZ's Avatar
BKSinAZ
Stock 103
hmmm... I wonder if the shifting of a 103 would be different than my 96.
I really cant see still being in 3rd gear @ 55 mph on my stock 96
Old Sep 17, 2012 | 07:17 PM
rubberfrog's Avatar
rubberfrog
That could be. I don't cruise at 55 in third. I'll hit fourth and back off. I just don't like to shift early right as the power and is coming on strong. For cruising, I like lower rpms.
Old Sep 17, 2012 | 07:20 PM
Dynam1te's Avatar
Dynam1te
Id say yours is pretty close to my 96. Maybe a bit on the early side. Don't be afraid to give it a bit more rev's. Like others have said, it is better to rev up a bit than lug the engine. Besides, if you're worried about MPG, last time I filled up, I got 45mph. Which is too good if you ask me...
Old Sep 17, 2012 | 07:21 PM
FXDWG12's Avatar
FXDWG12
This is my first Harley so I am curious if all Stocks are about the same. It seems that I..
On my 2012 Super Glide 96..
Is this about what you all shift? Don't get me wrong, I do listen/feel the revs and shift correctly, but I am just curious if this falls inline with other stock Dynas.
I think that your shifting pretty close to correct. These engines do like a little more RPM's though. I myself had a hard time finding the best shif points on my new Wide Glide. Using engine noises to judge the shift point will make you want to shift at higher RPM's. Adding aftermarket exhaust helped me. I personally believe that I can judge the exhaust note better for shifting.
Old Sep 17, 2012 | 07:22 PM
BKSinAZ's Avatar
BKSinAZ
thanks... I will attempt to give it a bit more revs before shifting.
Tell me... why is lugging bad? What harm does it do?
