Rear fender
Old Oct 23, 2012 | 07:59 PM
Bibber48's Avatar
Bibber48
Default Rear fender
Has anyone tried a Switchback rear fender on a street bob? Is it the same width? If so any pics?
Old Oct 24, 2012 | 12:39 AM
SURFOR Chop's Avatar
SURFOR Chop
Forum members 02fx4dude ...
and skip3406 ...
have installed the FLD Switchback rear fender on a Low Rider and Super Glide Custom, respectively ...
I believe the fender strut width of their bikes should be same as your Street Bob ... As I recall, there is a need for about 1/8" spacer between the strut and fender ... but, is pretty much a bolt on operation ...
Originally Posted by 02fx4dude
60400-12DH Rear fender vivid black $320
73380-12 Base for tail light $32
68770-02B wiring harness w/conduit $30
complete tail light/turn signal assembly from street glide $82 ebay
Parts catalog showed some interesting looking hardware for mounting the fender on the FLD, I used my hardware and spacers from my Low rider, and I think some 1/8" spacers from the hardware store since the FLD fender is narrower.
Good luck and if you PM either of those fellas, I am sure they'll answer any specific questions you may have ...
R/
'Chop
Old Oct 24, 2012 | 09:06 AM
skip3406's Avatar
skip3406
The only thing I did different form 02fx4dude was I bought the fender mounting brackets because they also help support the tail light/turn signal assembly part #57300001 left & 57300002 right $18.80 ea from surdyke HD
The spacer is 3/16" and I'm sure 1/8" washers will work like 02fx4dude did. You must use also use the front spacer that is on your fender now.
I got the spacers from a friend the put the detachable back rest on his FLD.
I think with the inner support barakets you might be able to mount the fender without the 1/8_3/16 spacers.
You didn't say what year street bob you have. If you have a 07-08 regular fender & tail light you only need #73381-12 BASE TAIL LIGHT ASSEMBLY. The CIRCUIT BOARD Part # 68830-99A is the same
I have a Pirelli Night Dragon 180/60 -17 on it now and it just barely clears.
Old Oct 24, 2012 | 09:14 AM
Bibber48's Avatar
Bibber48
Default Rear Fender
I have a 2010 Street Bob. I am curious about the fender bacause I want to eliminate the taillight. I have 2 different fenders and am trying to decide which to use. Thanks to all who replied.
Bowhunter8607
Aug 19, 2021 11:49 AM
Miles Cundiff
Jun 3, 2019 10:51 AM
inkpen00
Apr 3, 2014 06:43 AM
WoodrowWillson
Feb 29, 2012 10:30 PM
nichiowa
Oct 3, 2011 02:04 PM
