Broke a wiring pin, help?
Old Dec 1, 2012 | 01:00 AM
BlackNBlue's Avatar
BlackNBlue
1st Gear
Default Broke a wiring pin, help?
While I was installing my new handlebars today, I managed to break one of the pins on the end of one of the wires. Anyone know if these can be purchased and replaced? or am I looking at purchasing a kit?
Old Dec 1, 2012 | 01:08 AM
crimson13's Avatar
crimson13
You can purchase them , I might have some extra ones I will check for you when I get home
Old Dec 1, 2012 | 03:33 AM
Foxster's Avatar
Foxster
I think you are looking for a 72169-07.
Old Dec 1, 2012 | 05:31 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
If it's a pin in the HOUSING, 6-way pin (black) at the end of the handlebar switches' wiring you'll need a TERMINAL, pin, #16-20 AWG p/n 72169-07.
If it's a pin from the front turn signal wiring or the headlight wiring socket, you'll need a TERMINAL, socket, #16-20 AWG p/n 73191-96
73191-96:
Here's a link to a post in the HOW TO thread on how to remove the contact sockets from the socket housing:
post# 1092 …… AMP fitting release tool ............................... mud
72169-07:
Originally Posted by 08fxdf43202
....Then (working one wire at a time) strip each end & insert into a terminal pin... [/FONT][/COLOR]
Use the wire cutters to carefully ‘fold over’ each of the four tabs of each pin onto the wire...
Apply a small amount of solder to connect the wire to the pin and give a ‘test pull’ when the pin cools...
Terminate all the wires and re-assemble the connectors.
Old Dec 1, 2012 | 06:46 AM
crimson13's Avatar
crimson13
I got a couple extra ones ( 72169-07 ) if you want them let me know.
Old Dec 1, 2012 | 10:07 AM
BlackNBlue's Avatar
BlackNBlue
1st Gear
thats the one! one of the 8 from the clutch side. I will check and see if the dealer has any today, if not, I will let you know. Thanks !
Old Dec 2, 2012 | 11:03 AM
BlackNBlue's Avatar
BlackNBlue
1st Gear
got a few at my dealer for a buck. Thanks!
fffffish
Jun 4, 2012 11:04 AM
frogbite
16
Dec 23, 2011 08:49 AM
beeker356
Apr 4, 2011 05:24 PM
sym95734
Feb 18, 2010 09:08 AM
Fire4Effect
Jul 3, 2009 08:31 PM
