superglide dual disks
Old Dec 1, 2012 | 03:07 PM
Rampant's Avatar
Rampant
Default superglide dual disks
How expensive/hard is it to put a second front disk on a superglide (2008)?
I also want to black out the engine... is this pricey?
Old Dec 2, 2012 | 09:15 PM
Rampant's Avatar
Rampant
Anybody? What does this take?
Old Dec 2, 2012 | 09:28 PM
Warrior 72's Avatar
Warrior 72
From what I've read, it is pretty darn expensive. You have to get a right side lower fork leg, another rotor and caliper, new brake line, and a new/larger master cylinder. You can use a Brembo/touring caliper, and you will need a larger disk. You will still only have one disk but a larger disc and a much better caliper. Check this discussion out.
https://www.hdforums.com/forum/dyna-...r-upgrade.html
Old Dec 2, 2012 | 10:41 PM
Rampant's Avatar
Rampant
hrmm, but apparently you can just upgrade the one rotor and/or the caliper to have more pistons?
Old Dec 2, 2012 | 10:59 PM
07bobber's Avatar
07bobber
Either way it's gonna cost some bux..it's around $500 on up if u do it yourself, I still haven't finished my dual disk setup since Christmas takes priority. But I'm at $315 right now for everything but still need pads and brake line $80+$150 so ill be right around 550 when it's finished
Old Dec 3, 2012 | 09:02 AM
Good_Apollo's Avatar
Good_Apollo
If you can find the parts used, it will still be cheaper than doing a 6-piston caliper upgrade on the one side.
tonebone_79
Feb 9, 2016 01:10 PM
Jumpman
May 22, 2015 08:50 PM
vickers1
Jun 15, 2010 07:03 PM
Rev00
Oct 25, 2007 03:43 PM
ChrisB
Ironhead
Aug 7, 2007 02:33 PM
