Easy Bracket installation help!
Old Jan 21, 2013 | 08:10 PM
Mixter's Avatar
Mixter
Default Easy Bracket installation help!
I bought some saddlebags and easy brackets off of a forum member. They came off of a 2007 street bob and are going on my wife's 2007 street bob. Having trouble mounting the long bolt that bolts to the fender where the turn signals used to be. Unless i'm missing some pieces I can't figure out how they mount as the bolts seem long.
Any help would be appreciated. can't seem to find the instructions on line and the only demo video is for a softail.
Old Jan 21, 2013 | 08:16 PM
Lo 1's Avatar
Lo 1
The bolts replace the fender strut bolts. Remove the strut bolts, place the hardware onto the bolt and screw into place. Should be that simple. I used the easy brackets for 2 years with no problem.
Old Jan 21, 2013 | 08:24 PM
Silver Fox's Avatar
Silver Fox
The bolts may be long enough to accommodate a removable backrest. May need shorter bolts with no backrest.
Old Jan 21, 2013 | 08:48 PM
Mixter's Avatar
Mixter
Ok I'll check the length. But they don't screw in they just go right through the fender
Old Jan 21, 2013 | 09:00 PM
Lo 1's Avatar
Lo 1
If the bolts slip through the hole in the fender strut then its not the right size. How do they compare in size to the original strut bolts?
Old Jan 21, 2013 | 09:51 PM
Mike Horrell's Avatar
Mike Horrell
Take one of the stock bolts to a hardware store, find a nut that will fit it, then find a new
HARDENED bolt the length of the kit bolt that will fit the nut.. buy several.. problem cured...
Old Jan 21, 2013 | 10:02 PM
Mixter's Avatar
Mixter
Thanks guys. The bolts look to be the right size but there is nothing to thread into. The stock bolts came through the fender outwards and screwed into the turn signals.
Old Jan 21, 2013 | 10:06 PM
128auto's Avatar
128auto
You live in Vancouver right? I just installed a set of detachable bags on my 07 SB, call me at work tomorrow, I will tell you what to do. PM me for my contact number ok
Old Jan 21, 2013 | 10:18 PM
Mixter's Avatar
Mixter
Pm sent. Thanks!
Old Jan 21, 2013 | 10:25 PM
128auto's Avatar
128auto
Got it!
flhxmc
Feb 19, 2013 01:32 PM
mballinger
EVO
Feb 6, 2011 11:51 AM
ulev1st
Nov 24, 2010 02:35 PM
Skyking75
Feb 3, 2009 07:12 PM
jbroughton
Oct 23, 2006 11:38 PM
