I need some help with code po563
Old Jan 26, 2013 | 09:21 PM
dirtdobber's Avatar
dirtdobber
It is putting out with in specs
the ground cable to the frame was badly corroded.
After cleaning and reinstalling the light has not come on again.
I checked both the Regulator and stator. Both checked good. It is producing a good charge tot he battery. Off battery is 11.9 volts, idle it is 13,8 volts and at speed or higher rpm over 14 volts
No codes has been thrown. It will be checked when it is taken apart for the build. it will be removed any way for the case boring and tim... bearings to be installed.
This build is a top notch build, no short cuts being taken. The lower end will be bullet prof as much as one can be. Even the top end will be beyond any street bike standards.
It is being built as a racer standards.
thank you for reminding me
dd
Bobber Jay
Jun 16, 2019 05:38 PM
adam31093
Sep 4, 2013 07:29 PM
WOLFE1584
Mar 11, 2013 05:57 PM
dirtdobber
Jan 26, 2013 05:35 PM
darrinfish
Aug 22, 2010 07:27 AM
