Front susp?? Mine sucks
Old Jan 27, 2013 | 08:51 PM
Juan L's Avatar
Juan L
Moderator
I'd get a service manual first thing. I don't know everything a Street Bob has in the forks. I don't think I've ever seen a foot long length of tube in the fork but it could be in there for the spring to ride inside?
There is obviously a problem with your set up and it is probably not safe to ride and at the very minimum could damage the forks not to mention you.
Old Jan 27, 2013 | 08:53 PM
Juan L's Avatar
Juan L
Moderator
This thread has some good stuff in it:
https://www.hdforums.com/forum/dyna-...eet-bob-2.html
Can you post a picture of the "tubes" that your brother pulled out?
Old Jan 27, 2013 | 09:09 PM
rooti's Avatar
rooti
[quote]
You can replace the springs with constant rate from RaceTech and trim the spacer to any length to get your setup.QUOTE]
Race tech does not make a constant rate fork spring for the dyna. I would not use the spacer to lower your bike. The spacer is to set up the proper sag. There are many different ways to go with your front forks but until you get the proper sag set up, you will just keep throwing money at a problem that you never solved.
One you get it set up properly, throw in some ricor intimidators with some amsoil shock therapy fork oil.
For now, park it and do some more reading so you can come up with a better plan.
Old Jan 27, 2013 | 09:32 PM
Juan L's Avatar
Juan L
Moderator
[quote=rooti;10832628]
I'd put in the Intiminators while doing this so you don't have to go back in and trim the spacer even more. I did this change on my Road King and it made a HUGE difference!
I thought all of Race-Techs springs were straight rate..sorry for the bad info.
Old Jan 27, 2013 | 09:37 PM
rooti's Avatar
rooti
what did your sag come out to? I checked into the single rate fork springs for the 49mm dyna forks and traxxion is the only one that makes them. Kinda hard to believe huh.
Old Jan 27, 2013 | 09:41 PM
_LostSoul_'s Avatar
_LostSoul_
Here's a link with an exploded view and part numbers for your forks. Just punch in you info
http://www.shopronniesharleydavidson...partfinder.htm
Old Jan 27, 2013 | 09:42 PM
rooti's Avatar
rooti
link didn't work
Old Jan 27, 2013 | 09:45 PM
Juan L's Avatar
Juan L
Moderator
Got it set to 3/4" with 3 7/8" spacers, Race Tech 1.0 springs, and Ricor Intiminators.
Old Jan 27, 2013 | 09:48 PM
rooti's Avatar
rooti
did you use the "modded intimidators"?
By the way, nice king, love the classic. What part of Texas are you in?
Old Jan 27, 2013 | 09:53 PM
_LostSoul_'s Avatar
_LostSoul_
Fixed the link. Just punch in your info
