03 fxdl progressive front fork spring swap questions
Old Feb 14, 2013 | 04:53 PM
  #31
rooti's Avatar
rooti
Here read through some of this post and decide for yourself.
https://www.hdforums.com/forum/dyna-...uestion-2.html
Old Feb 14, 2013 | 07:27 PM
  #32
seniorsuperglideE8's Avatar
seniorsuperglideE8
Just did this last fall before the bikes were put away. Drain the fork oil thru the bottom drain scew. Lift the front just so the wheel is off the ground, loosen upper pinch bolts on the upper tree. Cover the gas tank and fender. In my case the handle bars came off (02 FXD) loosen the fork cap, keep in mind it's under a spring preload. The oil replacement works out to 10.7 ozs., 11 will work. I used Bel Ray 10w. Easy job for a competent mech.
Forgot to mention I have the Progressive 412's on the back, riding like a different bike, especially two up.
Old Feb 14, 2013 | 10:25 PM
  #33
03Custom883's Avatar
03Custom883
Rotti thanks for the link looks like air shocks are out. Progressive 412 or better is the way
I would go. Senior thanks for the info on the rears will give the 412's a shot
FATKEVIN
Jan 24, 2012 04:39 PM
SURFOR Chop
Mar 15, 2011 08:20 AM
harley_jeff
Jul 25, 2010 10:52 PM
smithbrl
Apr 16, 2010 08:37 AM
Titan56
Aug 15, 2009 03:13 PM
