What bike are you looking at putting the new console on ...? Your Fat Bob ...?
If you're thinking of doing a Street Bob console you will need to swap your stock 5" speedo for a 4" speedo ...
Also, as you noted in your original post ... you would need to either relocate the ignition switch or cut a hole in the dash to mount your ignition ...
I just installed the Wide Glide dash ... if you do it, you should look at the '10 or '11 dash ... the new dash relocated the odometer reset switch from the console to the horn button ...
... if you were to go that route, you'd need a 4" speedo ...
What is the Harley Part number for this dash panel, I am doing a custom build and I like this one alot
