Electrical problems - 2009 FXD
2009 FXD (approx. 20,000mi.) - A few months back my bike was getting harder and harder to start. This went on for a couple of months. It would struggle to start and eventually fire up. One night I went to start it and it tried a few times and then click, click, click.
Well, I parked it for a while and got a new battery when I had the dough. I tested the old battery with a voltmeter - 10.38v. Dead as a doornail.
I put in the new battery and tested it with the voltmeter - 12.68v. I started it (fired right up , first crank) I let it run a good 3 minutes or so and tested it again - 14.385v.
I figured the problem was fixed. I rode it about a week, and now it is starting rough again. I'm sure I didn't do anything wrong putting the battery in and the connections are clean and tight.
I'm thinking it may be a bad ground or maybe a short somewhere. Anybody have some suggestions of common weak points to check out? I have the manual, but it doesn't really tell you exactly where everything is.
I appreciate the help!
