fork Preload Adjusters
Old Mar 27, 2013 | 09:27 PM
  #61
ravnos5811's Avatar
ravnos5811
I wanted to add an update. I finally got home early enough to work on the bike after work. I was installing a progressive drop in kit and speed merchant pre load adjusters.
Pulled the stock fork caps off. Removed the stock spacer and spring. Dropped in my new springs. I go to screw in the Speed Merchant adjusters and I can't get the threads to line up. I pull the spacer and try without the spring pressure. Still not lining up great. I tried both sides several times with and without the spacers to no luck. In the end I reinstalled the stock fork caps.
I plan to contact speed merchant tomorrow and see if I missed something. It should of been an easy install. I am happy with my progressive drop ins.
Old Mar 27, 2013 | 09:34 PM
  #62
El Chiguete's Avatar
El Chiguete
Interesting... lets see what they say.
Old Mar 28, 2013 | 02:28 AM
  #63
fat bastard 68's Avatar
fat bastard 68
Sheeeet, I just about to get some, where's the best place to order from? Directly from Speed Merchants?
Old Mar 28, 2013 | 11:29 AM
  #64
ravnos5811's Avatar
ravnos5811
I ordered mine directly from Speed Merchant. Shipped the next day and showed up quickly since I'm in Cali also.
I also just got off the Phone with Brandon at Speed merchant. Great guy. Great Service. We walked through my install. Trouble shot the problem. When I get home, I'm going to give it another go.
Old Mar 28, 2013 | 11:22 PM
  #65
ravnos5811's Avatar
ravnos5811
After talking with Brandon from Speed Merchant today and follow his advice, everything installed easily. I'll give an update on how well they work after I ride the next few days..
Old Mar 29, 2013 | 04:26 AM
  #66
fat bastard 68
Looking good!
Old Apr 1, 2013 | 11:39 AM
  #67
ravnos5811's Avatar
ravnos5811
So I rode all weekend with the SM adjusters installed. Friday to and from work. Saturday some two up riding to a bbq. Sunday rode around a bit before easter dinner. All told a bit over 100 miles. I'm happy with the purchase. I cut done the spacers pretty close but this allowed me to fine tune the front pretty close to what I want.
Old Apr 1, 2013 | 12:31 PM
  #68
El Chiguete
So what was the problem and what did he say for you to fix it?
Old Apr 1, 2013 | 12:44 PM
  #69
ravnos5811's Avatar
ravnos5811
He suggested I cut down the spacer futher then I originally did. I also guess I didn't back out the pinch bolt enough so there was some pressure left on the tube. Once i did both it went in pretty easy.
Old Apr 1, 2013 | 12:45 PM
  #70
El Chiguete
Did you change the setup depending if you rode alone or 2up? do the instructions talk about that?
