throttle sticking
Old Feb 20, 2013 | 07:13 PM
jettchoppers69's Avatar
jettchoppers69
Default throttle sticking
ok i just put new bars and avon grips on my 08 dyna and the throttle is sticking, any sugestions?
Old Feb 20, 2013 | 07:15 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Adjust the throttle and idle cables. Might as well lube them while you are in there too.
Old Feb 20, 2013 | 07:23 PM
8541hog's Avatar
8541hog
Get some emory cloth like plumbers use and clean up your bars under the grip. My son just installed a set of Avons and had the exact issue. Don't use grease on the bars, it will only gum things up as it collects dirt.
Old Feb 20, 2013 | 07:31 PM
HD Pilot's Avatar
HD Pilot
Look inside the throttle grip for any glue leftover from the manufacture. My Kuryakyn ISO grips had some towards the end of the grip - unusable.
Old Feb 20, 2013 | 07:48 PM
Rfc's Avatar
Rfc
I just installed avons on mine last week and had the same problem. Turned out the grip was binding on the end of handle bar. Avons are a little shorter than stock grips. Loosen the 4 screws on on your switch assembly and move it out towards the end of handle bar, that should cure your problem.
Old Feb 20, 2013 | 08:07 PM
Mike650's Avatar
Mike650
had the same problem. +1 on what RFC said. also once i took it out for a ride it was fine.
Old Feb 20, 2013 | 08:23 PM
jmeiers's Avatar
jmeiers
+100
Make sure you adjust it per the manual too. What may work great with the bars pointed straight ahead may not work very well with the bars turned to the far right.
Old Feb 20, 2013 | 08:27 PM
ny switchback's Avatar
ny switchback
I put apes on my bike and worked on the cables for a couple of days until I friend of mine told me that I needed to lube them. Works great now.
RomeoTango
Sep 2, 2017 05:26 PM
Maxxsmart
Mar 3, 2016 10:05 AM
tacoma5432
May 25, 2011 07:40 PM
scot210
May 4, 2011 07:29 AM
rpmarkley
Apr 22, 2009 11:05 PM
